Where should i install this x pipe
Old Aug 24, 2016 | 12:11 PM
Pachara's Avatar
Pachara
Default Where should i install this x pipe
I got the injen ses exhaust with a berk test pipe and inside the car is really noisy so i bought this x pipe but i dont know where should i put it and how to install it, should i cut only the resonator out or take off the whole part and just make a new custom pipe and weld it to the x pipe
Old Aug 24, 2016 | 01:59 PM
Conway_160's Avatar
Conway_160
WTF, if your going to use a X-pipe get a knock off exhaust not a legit one!
Old Aug 24, 2016 | 02:15 PM
Pachara's Avatar
Pachara
What do u mean i just wanna get rid of the drone noise in my car bro and i saw some post said i need an x pipe
Old Aug 24, 2016 | 03:13 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Ideally, placing a balance pipe closest to the front of the car, roughly 12-18" aft of the collector pipes will be most effective. In your case, installation just aft of the front resonator should help quiet it down a bit, along with a slight power increase.
Old Aug 25, 2016 | 04:41 AM
Pachara's Avatar
Pachara
Thanks bro what if I cut the resonator and replace it with this
Old Aug 25, 2016 | 04:54 AM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Doesn't this already have a x pipe inside of it?
Just resonated x pipe so you dont see it... If you remove that your going to be sad if you think the drone is badbed now.
Old Aug 25, 2016 | 04:57 AM
dboyzalter's Avatar
dboyzalter
The noise is from your test pipes... You need resonated test pipes or cats if you want to make things less noisy. That x pipe is not going to help anything.
Best idea would be return it and get some differential bushings... Like what I did their..
Old Aug 25, 2016 | 04:59 AM
Pachara's Avatar
Pachara
So what should i do 😢
Old Aug 25, 2016 | 05:02 AM
dboyzalter's Avatar
dboyzalter
Get resonated test pipes or catalytic converters... Thats your issue.
Pachara's Avatar
Pachara
I like it to be loud but not the drone noise in the car
Old Aug 25, 2016 | 05:19 AM
turboed350z's Avatar
turboed350z
If you want loud, sell the 350z buy a 427 v8 open headers mean as cam and there will only be a handful of csrs that can be louder than that
Old Aug 29, 2016 | 07:39 PM
generalkenobi08's Avatar
generalkenobi08
I drove around with Kinetix test pipes for about 30 minutes and could not stand the noise. Switched to the Motordyne ART pipes and was blown away by the difference. They were pricey but worth the cost in my opinion. I cannot vouch for any other resonated test pipes.
Old Aug 29, 2016 | 08:15 PM
KJFire4Life's Avatar
KJFire4Life
If you like it loud outside but quiet inside there is a SIMPLE solution. Pull your trunk apart, use Dynamat on everything, pull your doors apart, same thing (in moderation...remember the window mechanism is in there, you can also use the cheap lowes stuff to do the roof under headliner and area under the seats. I can guarantee you 100% that you'll cut you're noise level in the cab in half
Old Aug 30, 2016 | 04:56 AM
travlee's Avatar
travlee
Master
Z33E
May 3, 2016 09:48 PM
phreaktor
North East Marketplace
Apr 8, 2016 05:13 PM
