Crawford vs. Kinetix Plenum Shootout!
Old Feb 17, 2004 | 08:29 PM
  #61
little_rod's Avatar
little_rod
Love the pictures. Would still love to see a picture of the kinetix plenum with the stock bar over it though (can never make us happy ).
Old Feb 17, 2004 | 08:47 PM
  #62
Apexi350z's Avatar
Apexi350z
Charter Member #50
this was from all_bark's setup.
Old Feb 17, 2004 | 08:49 PM
  #63
Apexi350z's Avatar
Apexi350z
Charter Member #50
with the engine cover..
Old Feb 17, 2004 | 09:04 PM
  #64
little_rod's Avatar
little_rod
Does the kinetix touch the strut bar?? I mean, it looks awful close.
Old Feb 17, 2004 | 10:07 PM
  #65
Z8M's Avatar
Z8M
Wow! I thought I'll never see an aftermarket plenum with the stock strut bar. Outstanding job LSD!! That engine looks great.. I will definately order this.
Old Feb 18, 2004 | 05:10 AM
  #66
TheBigShow's Avatar
TheBigShow
will the production plenum match the black of the engine cover better than that?
Old Feb 18, 2004 | 05:23 AM
  #67
Ak1nza's Avatar
Ak1nza
Is there any news of development of a plenum without a dip?
I hope ppl aren't annoyed that I keep asking. :P
I'd really like to get a KR plenum, but don't want to have a dip I won't be using. I don't plan on using my stock cover after installing the plenum either cos I think it looks great out in the open!
Old Feb 18, 2004 | 05:28 AM
  #68
cinergi1's Avatar
cinergi1
Look at the pictures of my plenum. It's a production version and has the color fix. It matches the factory cover quite well.
Old Feb 18, 2004 | 07:38 AM
  #69
Apexi350z's Avatar
Apexi350z
Charter Member #50
I don't think it does, and also I'm sure LSD will MAKE sure the stb doesn't touch the plenum..He has been making very quality products..
Old Feb 18, 2004 | 04:12 PM
  #70
D'oh's Avatar
D'oh
Last I heard was that there would not be a different version without the dip because that would require a different mold.
-D'oh!
Old Feb 18, 2004 | 05:06 PM
  #71
SungNamZ's Avatar
SungNamZ
Originally posted by cinergi1
And the Kinetix:
Title: 2004 Infiniti G35
Run Date and Time: 2/16/2004 9:41:50 AM
Acceleration from 2300 to 6900RPM, interval = 100.00RPM
Absolute barometric pressure : 29.35 in.Hg.
Vapor pressure : 0.26 in.Hg.
Intake air temperature : 72.3 °F
Gear Ratio : 46.32 RPM/MPH
Correction Factor : 3.00 SAE
TIME RPM TORQUE POWER AIR/FUEL
0.00 2300 185.9 81.4 14.7
0.40 2400 226.5 103.5 14.8
0.78 2500 229.9 109.5 14.5
1.16 2600 226.8 112.3 13.8
1.55 2700 225.8 116.1 13.5
1.93 2800 229.5 122.3 13.4
2.31 2900 233.8 129.1 13.3
2.68 3000 236.2 134.9 13.1
3.05 3100 240.3 141.9 13.1
3.41 3200 242.2 147.6 13.2
3.77 3300 241.8 151.9 13.2
4.14 3400 240.9 156.0 13.2
4.50 3500 240.6 160.3 13.3
4.87 3600 241.2 165.3 13.2
5.23 3700 243.2 171.3 13.2
5.59 3800 244.8 177.1 13.1
5.95 3900 244.4 181.5 13.1
6.30 4000 245.0 186.6 13.1
6.66 4100 247.0 192.8 13.2
7.02 4200 247.9 198.3 13.2
7.37 4300 249.1 204.0 13.1
7.72 4400 249.7 209.1 13.0
8.08 4500 249.9 214.0 13.0
8.43 4600 249.1 218.2 12.9
8.78 4700 248.1 222.0 12.9
9.14 4800 246.2 225.0 12.8
9.50 4900 246.0 229.5 12.9
9.86 5000 242.8 231.1 13.0
10.22 5100 239.7 232.8 13.0
10.59 5200 237.8 235.4 12.8
10.97 5300 235.7 237.9 12.8
11.34 5400 233.5 240.1 12.7
11.72 5500 232.6 243.5 12.6
12.11 5600 230.4 245.7 12.7
12.49 5700 227.8 247.2 12.8
12.88 5800 224.8 248.3 12.8
13.28 5900 222.3 249.7 12.9
13.68 6000 218.7 249.8 12.9
14.09 6100 216.5 251.5 12.9
14.51 6200 214.4 253.8 12.9
14.93 6300 209.3 251.1 12.9
15.36 6400 203.4 247.8 12.8
15.81 6500 197.2 244.0 12.8
16.27 6600 190.0 238.8 12.9
16.75 6700 182.2 232.4 12.8
17.25 6800 179.3 232.1 12.8
17.77 6900 162.7 213.8 12.8
Column Max 249.9 253.8 14.8
Column Min 162.7 81.4 12.6
Column Average 228.8 197.6 13.1
I for one will be installing Kinetix Plenum and Cats immediately upon availability/ordering/receiving. Have never done a Dyno Test on any vehicle I have owned until now. Here is my baseline:
Miles: 24,000 Modifications: Borla Exhaust, Grounding Kit, Denso Iridium Plugs and K&N Panel Filter.
Old Feb 19, 2004 | 09:50 AM
  #72
aggie300zx's Avatar
aggie300zx
I know this probably is stretching things a bit but here goes...
So based on these results would my logic be accurate in stating that the Crawford Plenum + Cats vs. the Kinetix Plenum + Cats would yield you similar performance results? My reasoning is obviously based on these results in regards to the plenum and on the fact that both Hi-flow cat versions use the same converters.
If that's the case then it basically comes down to price, looks, core-charge/exchange.
Flame on...
Old Feb 20, 2004 | 01:19 PM
  #73
ZxRage's Avatar
ZxRage
So does anyone know when they will be available to purchase? I would like to get one. And then I will have to get an Apexi SAFC2 as well to tune it.
Old Feb 20, 2004 | 02:57 PM
  #74
Apexi350z's Avatar
Apexi350z
Charter Member #50
Flame on...
you are correct sir!
Old Feb 20, 2004 | 04:11 PM
  #75
lsdunique's Avatar
lsdunique
I would say that is a very safe assumption.
I would think both packages would post very similar gains.
The plenum will be up on our website starting this Sunday morning. As well as a discounted plenum/high flow cat package.
Old Feb 20, 2004 | 06:29 PM
  #76
blug35c's Avatar
blug35c
I for one will be using the Crawford Plenum. Don't want to have to be concerned with plastic upper plenum vs aluminum lower plenum and if it cracks or splinters, having the stuff go into my engine.
Old Feb 20, 2004 | 06:48 PM
  #77
daytona350zr's Avatar
daytona350zr
i will also be going with the crawford plenum ver. 5. I would feel safer going with something that has been out for a while.
Old Feb 20, 2004 | 07:13 PM
  #78
Apexi350z's Avatar
Apexi350z
Charter Member #50
Sunday morning around what time?
Is it first come first serve?
btw, have you ship out the initial pre-release batch (all_bark's list?)
Old Feb 20, 2004 | 09:30 PM
  #79
lsdunique's Avatar
lsdunique
the plenum orders placed this sunday are first come first serve, and will start shipping Feb 29th.
The priority list orders have already been placed and will ship out Feb 25th.
I would expect to see the plenum on the website around 10:30 am
Old Feb 21, 2004 | 07:43 AM
  #80
reallyredZ's Avatar
reallyredZ
It comes down to price and strutbar for me. The plastic doesn't bother be, because the lower intake manifolds for the 4.6 mustang GT and I think the LS1 are made out of plastic. No problems there with them.
