What's that sound?
I came back from a trip and went to take out my 2004 350Z Roadster with 50,000 mi, and noticed a raspy exhaust note that wasn't there before. Drove it anyway and felt a loss in low end power (responsiveness).
Eventually the "check engine" light came on. I took it to two auto parts stores and they both came up with the same P-0300 code (Multiple misfires).
Took it to a mechanic who replaced one of the battery terminals that he said was loose and arcing and cleaned the negative connection, re-set the computer. Car seemed fine but the noise is still there. A day later, the check engine light flickered on and off.
I have to take it back to the mechanic to look deeper into the situation and I'm wondering if anyone has a thought about the engine issue and the odd exhaust note being related.
Thanks everyone!
Thanks everyone!
First easy and quick thing to do is check the spark plugs and also check for a vacuum leak. Spark plugs by themselves can tell how the engine is or isn't running properly. Also by checking the spark plugs you can tell wether you have a valve cover leak in the tube which can cause a miss fire.
sentry65
Dec 19, 2004 06:56 AM
