Flooded my Z, misfiring, need help
Old Dec 14, 2012 | 01:22 PM
Warku's Avatar
Warku
Default Flooded my Z, misfiring, need help
Okay, so about two months ago, I flooded my Z by hitting a dip filled wih water that came up to about the headlights at about 40 MPH. It wouldn't start at first, but I took out the spark plugs, turned it over so the water inside would spew out, replaced the old spark plugs, and she started. Drove fine-ish, still does, but there is a misfire every once in a while in the lower RPMs for sure. Hard to tell in the higher RPMs. This effects my torque and my gas mileage (It's really bad).
There IS a hole in the exhaust, but it doesn't effect it much except that it's louder and I think it may have something to do with the torque (I think).
I need to know what the possible deficiencies could be, so I can get this problem is fixed.
I'm not very mechanically inclined, so please be vivid on your responses if you would.
Thanks in advance to whoever responds.
Old Dec 14, 2012 | 05:25 PM
SlowNFurious's Avatar
SlowNFurious
Are you throwing any codes? Sounds like it could be a bad coil pack, but I you would probably have a check engine light if that were the case.
Old Dec 14, 2012 | 05:37 PM
Warku's Avatar
Warku
Actually, yes. Forgot to post that. My check engine light is blinking.
Old Dec 14, 2012 | 05:39 PM
SlowNFurious
Get it scanned and report your results.
Old Dec 14, 2012 | 05:41 PM
Warku's Avatar
Warku
It threw only the spark plugs.
Old Dec 14, 2012 | 05:55 PM
SlowNFurious
Im not an expert, but I don't think there is a code that could tell you specifically that it is a spark plug and not a bad coil pack. Can you post your codes?
Old Dec 14, 2012 | 06:03 PM
Warku's Avatar
Warku
Yeah, it was a while ago...I don't have them. I'll get it scanned again and post the actual codes.
Old Dec 15, 2012 | 03:30 AM
djamps's Avatar
djamps
Do a compression check.
Old Dec 15, 2012 | 03:44 AM
Warku's Avatar
Warku
Okay. I'm guessing there's a guide on how to do that on here?
Old Dec 15, 2012 | 07:57 AM
terrasmak's Avatar
A bent rod or two will cause problems, you need to tear your motor down.
Old Dec 15, 2012 | 08:03 AM
SlowNFurious
Yeah start with tearing the motor down, then if thats not the problem move on to smaller things. Not following this logic?
Also, he said the car runs better in the high rpms.
Old Dec 15, 2012 | 08:06 AM
terrasmak's Avatar
Most water locked motors bend rods , yes you can pull plugs , get the water out and fire it up, but it just a matter of time before the rods breaks. Typically it costs more to replace the motor with no core
OdesiTT
Sep 30, 2015 10:47 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
350Zzzz
Dec 16, 2003 08:12 PM
