Raspy, buzzing exhaust @2500-3000 rpm
Old Jun 30, 2004 | 09:52 PM
  #181
techz33's Avatar
techz33
Default Re: Raspy, buzzing exhaust @2500-3000 rpm
Originally posted by KISS
Does anyone else have this problem. I have Rt cats, JIC y-pipe and Magnaflow exhaust. The car sound fine but when I'm at 2500-3000 rpm's it buzzes. Sometimes I'll hear it on the highway at full throttle. I've heard some other Z owners have this problem.
I just installed the Rt cats and it now has atasp to it @2500 to 3000 rpm. So probably the cats are the reason for the rasp wich is not a problem it only means you have not had your car tuned since you installed the cats. Reason being with high flow cats you have less back presure witch results in running rich and less HP.To get the most out of your mods for the z33 you must flash and tune your ECU . You can try TECHNOSQUARE.COM
Old Jul 1, 2004 | 01:19 AM
  #182
chaparro78's Avatar
chaparro78
Default Re: Re: Raspy, buzzing exhaust @2500-3000 rpm
Resonators cure the rasp, and you don't have to spend $600 to get the technosquare flash which i doubt will cure the rasp. If you would have botherred to read the thread you would see that KISS solved his rasp issue with resonators, as did I
Old Jul 1, 2004 | 07:12 AM
  #183
myz8a4re's Avatar
myz8a4re
& so did i. i was the first person who ever mentioned the kinetix resonated test pipes(resonators in general actually). i even posted how they did the research & designed thier resonated pipes just for this reason. its funny, if you look back to when i first started replying you can see i was touching on this very issue but noone was listening. then when somone finally responded to what i was saying there was an argument about how wrong i was & thst there was still a major problem..........just funny how everyone is now going the resonator route, lol! im glad that somone had started applying thier own resonators to thier testpipes to save from overspending to eliminate the rasp. i still highly recommend the kinetix resonated pipes for those that have not went with test pipes yet. it will be about the same as if you purchase non resonated pipes & add your own resonators, just easier from the get go...............good luck!
-justin
Old Jul 1, 2004 | 09:11 AM
  #184
spf4000's Avatar
spf4000
Has anyone tried Nismo's cats to see if it has the same rasp problem as the other cats/test pipes?
Old Feb 3, 2005 | 02:52 PM
  #185
coachk's Avatar
coachk
ANT
Take a look at how chapparo78 solved his rasp problem .Lots of pics.
Old Feb 14, 2005 | 07:22 PM
  #186
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Moved.
Old Feb 18, 2005 | 11:25 AM
  #187
copba1t's Avatar
copba1t
Well, although this is not related directly to the topic, I had a vibration coming from the rear of the car at around 1.8 - 2k after installing a y-pipe and resonated test pipes (stock exhaust). It also made some strange noises at higher RPM's under WOT. I later swapped the test pipes out for hi-flow cats (for other reasons) and the vibration was still there.
Well it turns out it was the thin flimsy V-shaped air shield that is bolted onto the stock muffler. Everything was nice and tight, but apparently it's so thin that it just naturally resonates at those frequencies or something...?
So I ripped it off and the sound is gone. I don't really think the shield did much for airflow anyway, the stock muffler is already pretty oval in shape, you would probably have to be going 150 for it to make much difference.
Old Feb 19, 2005 | 09:26 PM
  #188
ReavTek's Avatar
ReavTek
You have any pics of that V shaped shield? Btw, what is "rasp"? I have a sound that sounds like a metal on metal vibration. This appeared with the install of my Stillen Test Pipes. Is this Rasp and would resonators cure them?
Also, where can I find a good muffler shop in FL?
Old Feb 25, 2005 | 11:13 AM
  #189
350Zenophile's Avatar
350Zenophile
I read all ten pages of this thread and I seem to be the only one with this setup...
TopSpeed Headers and Kinetix HF Cats.
I have the rasp at 3-4k rpm at WOT and wonder if anyone knows if replacing the HF Cats with resontated test pipes will improve or worsen this?
Old Feb 26, 2005 | 08:29 PM
  #190
kopo's Avatar
kopo
bump wondering the same thing
Old Feb 26, 2005 | 10:01 PM
  #191
Z BOY's Avatar
Z BOY
Originally posted by Z350Lover
don't know if anyone has brought this up... but in Nismo website, they put an end note at the end of their cats product page.... it says that their high flow cats will produce a metal rattle noise at around 3500 - 4000 rpm as well... and it is NORMAL!
so I guess most of the high flow cats will produce this kind of metal vibration due to the resonance....
cheers,
richie
BINGO! You get the gold ring, richie!
If the very manufacturer of our cars says the rasp is normal with their very own hf cats, then there's not much more to be said, imo, other than to find a type/brand of rasp you can live with for the gains produced, and move on to cracking the great ecu mystery!
Old Nov 14, 2006 | 06:33 PM
  #192
DanielW's Avatar
DanielW
most of you guys were talking about the test pipes. Don't the high flow cats have resonators on them?
Old Nov 14, 2006 | 06:34 PM
  #193
DanielW's Avatar
DanielW
I have ultimate racing hfc's and I'm getting the buzz. Shouldn't these be better than test pipes or even resonated test pipes?
Old Nov 16, 2006 | 08:13 AM
  #194
DanielW's Avatar
DanielW
bump
Old Nov 16, 2006 | 03:01 PM
  #195
diablo1356's Avatar
diablo1356
i have topspeed headers and kinetix HFC..and i do have that metal on metal ringing at certain rpm's (3-4)..its damn annoying and im thinking bout putting my stock cats back on and seeing if the problem is solved..ill post when i do
Old Nov 17, 2006 | 10:31 AM
  #196
DanielW's Avatar
DanielW
I'm going to be putting my car up on jack stands this weekend to see if its making a conection on the drivers side with the heat shield
Old Nov 18, 2006 | 07:10 AM
  #197
1redZ983's Avatar
1redZ983
i have the titek test pipes and im getting the rattling sound also. i checked underneath and i think its the flex pipes thats making the sound.
Old Nov 18, 2006 | 08:25 AM
  #198
DanielW's Avatar
DanielW
what are flex pipes?
Old Mar 13, 2011 | 01:35 AM
  #199
KingBaby's Avatar
KingBaby
Hardest Setting
let's bump an old a$$ thread why don't we...
the clip below is of my Z with *AAM test pipes & y-pipe, stock mid-pipe without the resonator and stock muffler. So I've read this thread and it's the only one with a distinct title to my problem.
BUZZING!
I don't mind rasp however much but this buzzing noise is killing me...
I might have an exhaust leak, cause I was excited while installing it so I might not have tighten down everything. I removed the metal heat shields above the muffler and the two over the test pipes. There is one more over the mid-pipe, I'm planning to remove it as well seeing that it might be it vibrating...
So in short I think it might be either of the following with my setup.
- mid-pipe without the resonator
- last heat shield over the mid-pipe
- chambers in the muffler itself
really don't want to ditch this parts due to the sound...cause the instant felt change it power was great...
EDIT:
Also the buzzing is from the very rear no where near the test pipes.
Old Mar 13, 2011 | 07:27 AM
  #200
rich2342's Avatar
rich2342
Sounds to me like rasp and metal vibration. I'm sure once the system heats up and it dissapates. Mine does have rasp when cold, once warmed up sounds very deep and just awesome, like an exhaust should sound.
