Raspy, buzzing exhaust @2500-3000 rpm
Old Apr 26, 2004 | 08:36 PM
  #101
F2dmfine's Avatar
F2dmfine
Well I am going to get my headers installed on this Thursday, and I will definitely post afterwards to see if i can detect exactly where the noise is coming from.
Old Apr 27, 2004 | 05:26 AM
  #102
BrianLG35C's Avatar
BrianLG35C
I'm dying to hear what you find out!
Old Apr 27, 2004 | 10:50 PM
  #103
scz's Avatar
scz
I had the same problem, and it has to do with the engine itself. There is rasp in this engine between 3-4k which is taken care of by the stock cats and resonators. I had the same problem when I put on the helix pipes with the stock resonators. But since I put on my exhaust I have literally no rasp at all. I think this is mostly due to the fact that the injen exhaust has a resonator on each pipe. A friend of mine has race pipes on his altima and a single to dual custom exhaust similar to the nismo. In order to get rid of the rasp, his performance shop modifies a resonator from a ferrari that cost him like $350 (normally $900) which took care of the rasp with a single midpipe exhaust setup.
Old Apr 28, 2004 | 09:18 AM
  #104
pharmboy's Avatar
pharmboy
nevermind...
Old Apr 28, 2004 | 04:56 PM
  #105
spf4000's Avatar
spf4000
Has anyone tried putting the stock cat back system back on to see if the lack of a tuned resonator in the middle pipe is in fact the cause of the problem?
Old Apr 28, 2004 | 08:09 PM
  #106
RCKTDAWG's Avatar
RCKTDAWG
I had the OEM muffler/resinator, RT Cats and JIC Y-Pipe and had the "buzzing" sound. I just installed a Fujitsubo Y-Pipe back exhaust tonight and it's still there.
  #107
scz's Avatar
scz
Obviously you didn't read what I said 2 posts ago.
Old May 6, 2004 | 11:05 AM
  #108
BrianLG35C's Avatar
BrianLG35C
Did you install the headers? Figure out where the rattle is coming from??
Old May 7, 2004 | 06:57 AM
  #109
jjellyneck's Avatar
jjellyneck
I've had Kinetix cats with the stock exhaust and the cats with a Borla. Never had the buzzing, except for the left cat rubbing against the heat shield during med-heavy throttle (engine is twisting in that direction).
Old May 7, 2004 | 04:19 PM
  #110
03 Z for ME's Avatar
03 Z for ME
I have the Borla True Dual with the Kinetixs cats. The ONLY time I have any Rasp is when I get OFF the throttle around 6-7K. It's a very short rasp that quickly disappears as soon as I get bak in the throttle.
My personal opinion is that it has to do with exhaust velocity and / or back pressure.
I LOVE my Kinetixs cats. I can live with a SHORT rasp every once and a while for the performance gains I got!
Old May 8, 2004 | 05:55 AM
  #111
sschmuve's Avatar
sschmuve
I've had the Injen SES for a while with no problems, and now I have a noise that just developed. My car makes a metalic raspy noise at low rpm (@2000), and under moderate to heavy throttle. And of course it doesn't do it while neutral reving, so I doubt I'll ever find it. I don't think its the Injen, but who knows....
Old May 8, 2004 | 11:12 AM
  #112
fdao's Avatar
fdao
Originally posted by Jsn350Z
I took them off for a number of reasons but i will be trying Crawford cats next. Havnt ever herd of Crawford cats being raspy at all.
I have the Crawfords CATS. I too have the raspiness between 3-4K. More pronounced when cold, but less once warmed up. If gradually accelerating through the rev range, not much of a rasp is noted; however, when WOT, there's definitely a rasp, even when warmed up .
Old May 10, 2004 | 06:10 AM
  #113
BrianLG35C's Avatar
BrianLG35C
Well there goes my possible cold weather theory for the buzzing problem. If you have the same problem in Hawaii, then my much colder weather definetly isn't the cause.
Old May 10, 2004 | 10:52 AM
  #114
fdao's Avatar
fdao
Yeah .
Old May 11, 2004 | 12:41 PM
  #115
KISS's Avatar
KISS
Does anyone have headers, y-pipe and so on with an Invidia/rsr type exhaust, and STILL have the buzzing? No matter what exhaust is used, it seem this sound is unavoidable. Is this what a race car sounds like? The more you open the exhaust, the more you hear the engine?????
Old May 11, 2004 | 01:10 PM
  #116
RCKTDAWG's Avatar
RCKTDAWG
Look at the post about 13 back (SCZ), Injen SES Exhaust. He said the buzz is non-existant with his duel resonator exhaust, but does it restrict somewhat?
Old May 11, 2004 | 03:26 PM
  #117
KISS's Avatar
KISS
The resonator is what it is, for resonation. I guess the engine is definitly tuned different. I don't think that resonators cause any restriction. Most are wide open pipes with perferated materials. I guess our cars need this to tune the sound. I have a 88 fiero gt v6 with wide open exhaust, headers, no cats with a flowmaster and it sounds like a v8. I was hoping my car might pick up some v8 characteristics.
Old May 11, 2004 | 03:50 PM
  #118
fdao's Avatar
fdao
Yeah. If you heard the JGTC 350Z, it sounds like sh*t. Perhaps it's the nature of the engine.
Old May 11, 2004 | 05:26 PM
  #119
jckolnturn's Avatar
jckolnturn
yeah but the NISMO exhaust has a resonator and i still get the noise
Old May 12, 2004 | 06:16 AM
  #120
BrianLG35C's Avatar
BrianLG35C
So you have Kinetix Cats and still you have the sound? I thought this Cat didn't have the rattle. Oh well. Man, I can't believe with all the motorheads on this forum, nobody has solved this. Maybe when I get dyno'd they can check the exhaust under torque load.
