CUSTOM INTAKE DONE AWESOME RESULTS W/ BLITZ HKS APEXi TRUST READ NOW WHY ITS BETTER!!
Old Mar 4, 2004 | 12:07 PM
rodH's Avatar
rodH
Wicked, isn't it funny that people call this a "ghetto mod", when in fact, you could claim it is 100% american built and ask for additional $$ based on this fact, in fact, I find that things you do to your car on your own (typically) you take more time and care to make it even better than a pre-bought piece.
btw, I was at autozone getting some brake pads for my wifes car and I head over to the ghetto section, and guess what they have??? AN adapter very similar looking to the one you make, but it is made out of "composite" (in other words "Plastic" ). I rushed home and it fits my K&N perfectly.
Now I just have to find the time to install it and figure out a good way to make a heat shield (if you have any ideas let me know, I and thinking about cutting up a bucket and painting it?? any other ideas??)
Old Mar 4, 2004 | 12:20 PM
Wicked4u2c's Avatar
Wicked4u2c
Originally posted by Chebosto
[B]the "Torando Air" P.O.S. is not the same as a velocity stack.
that thing tries to sprial air, as to create a vortex, so that air will accelerate. BUT it also fails to mention that its a huge air block, immense airflow is blocked.
a VELOCITY stack uses the venturi effect. how?
well first you have to understand what venturi is. venturi is when fluid speed increases when the fluid is forced through a narrow or restricted area.
simple diagram.
[A]>=<[B]
if you have the volume of A to goto B. so if gas A, say like normal air, it has to speed up through a narrow passage, so that the same amount of air that went in, comes out at box . sorta like conservation of energy.
well your MAF is a 3" diameter hole.
you have a 9" diameter pop charger filter. how do you get air from a 9inch wide filter into a 3inch hole? simple a velocity stack maf adapter.
its smooth gradual shape allows the airflow around the top edge of the toroid accelerate toward the center. (Toroid/torus, its like the shape of a donut) place a marble on the outter edge of an upsidedown bowl, and see the marble accelerate. same idea.
air will speed through the MAF at a higher rate than if you just have a simple filter at the end of it.
so if you do your dyno test again, with NO filter, and slap on just the velocity stack, you should get some good numbers since its sucking air from everywhere.
I understand the concept, what your not understanding is that all you have to do is find a good filter that has less restriction, the more open the better. The concept is very easy to understand but you have to remember your SUCKING air not RAMMING air inside. Take a straw for example.. Lets say your sucking on the straw as hard as you can... Your generating 5psi of Vaccum. Now pop in a velocity stack filter on that straw(lets just say a mini version of it). Your vaccum will most likely drop because you now have a bit of restriction not much but is some so lets say your at 4.5psi now... Your saying how the air will accelerate more quickly, but reality is the engine or in this case YOU. Can only suck 5psi of air period. Unless you A: Get cams and more intake volume can be sucked in this case bigger lungs OR B: Forced induction. Why don't you do the test so you can see that the whole velocity stack is somewhat tricky... I will keep saying this and AIR FILTER is just TO FILTER AIR, nothing more nothing less... Finding the less restrictive air filter isn't always the best... AS YOU CAN SEE FROM THE RESULTS, the CHINA filter made more power because it filters less and MORE AIR!!!! is getting inside. Plain and simple.
Old Mar 4, 2004 | 12:25 PM
Wicked4u2c's Avatar
Wicked4u2c
LOL, I agree with you. Actually this is funny. China tubing, MEXICAN inventor, AMERICAN WELDING IT, GOING ON A JAPANESE CAR... Yeah... GHETTO!!! LOL
But yeah, I do take more extra care and precautions and anyone doing anything custom normally does the extra steps to make that final touch, actually my friend who helped me welding it is now going to make his own. HE has an AEM intake and is going to make a 1 piece design. You know that plastic stock piece, well he is making that too all one piece! Creative, maybe.. UNIQUE yes! Good luck with your intake, E-mail me if you have any questions or give me a call i'll give you my cell phone.
GOOD LUCK!
Old Mar 4, 2004 | 01:29 PM
zxsaint's Avatar
zxsaint
Fairlady Stalker
Nice job...
This is good advice but for some, time = money (but that varies for each individual).
For me, spending over 2-3 hours on driving around, measuring, and fabricating this would run (in time spent) way over the $120 it costs to buy the JWT that includes the filter, cnc precision cut velocity stack adapter, mount, and heat shield.
But sounds like you had a great time putting it together... it's time well spent when it's a hobby. Again, well done on your intake/exhaust mods.
Old Mar 4, 2004 | 03:46 PM
Road Warrior's Avatar
Road Warrior
my thoughts exactly....although not conveyed that way due to my negativity...but it is innovative ideas and motivated individuals/enthusiasts that are the reason we have all these great mods from which to choose from in the aftermarket industry
any plans for production wicked4u2c...? since i am the reason for your mad creation i should be privy to a small percentage of your profits
Old Mar 4, 2004 | 04:10 PM
rodH's Avatar
rodH
Installed, Actually was very very easy when I got the adaptor.
car sounds same at idle, at WOT sounds totally different, a lot deeper, meaner sound. My car use to have a lot higher pitch sound at WOT (and the raspiness at 2-3k rpm, from the test pipes) now it sounds totally different.
Is that what what the JWT and what wickeds sounds like>????
Old Mar 4, 2004 | 07:58 PM
phile's Avatar
phile
Can you take a pic of the piece you bought and the filter you're using? Would be most appreciated
Old Mar 4, 2004 | 08:39 PM
rodH's Avatar
rodH
I am using a K&N cone filter, the adapter looks like this adapter...
but instead of a metal piece it is plastic
Old Mar 4, 2004 | 10:27 PM
redls1's Avatar
redls1
I already did the same thing and used a plastic heat shield I bought at autozone. I also got negativity when I first posted beacuse you were only saving xxx amount of dollars. I did it not only to save money but I enjoyed doing it knowing that i ACTUALLY DID IT MYSELF.
Old Mar 4, 2004 | 10:45 PM
D'oh's Avatar
D'oh
Just a question regarding the Venturi effect.
How exactly does a "velocity stack" improve flow? All it does is increase the speed of the air, but it will actually reduce the mass flow through the intake. Look at it this way - if you have a restriction (venturi) in your intake, we all know that the air will speed up. However, in order for the air to be accellerated, their needs to be some force acting on it. This force is the pressure difference between the one end of the restriction and the other. Now, the only way to create a pressure differential is to build up air on the upstream side of the intake. This means that in a N/A application, where engine vacuum is the only means of creating pressure, you are simply not allowing the engine to get as much air as it otherwise could. To me, this sounds like a bad thing.
I have not had significant experience with the design of venturis on car intakes, but from a fluid dynamics perspective, I don't yet understand how they would help. The only area I can see them helping is in the actual intake runners to each cylinder, where the air velocity can be used to help improve the flow into the cylinder. However, having a restriction right after the air filter doesn't seem like it would help.
Anyone have scientific reasons why these things are useful and how they work?
Thanks,
D'oh!
Old Mar 5, 2004 | 09:16 AM
PoWeRtRiP's Avatar
PoWeRtRiP
did you ever post the dyno that shows this 7.5 hp gain? i tried to find it but i cant...
Old Mar 5, 2004 | 11:45 AM
rodH's Avatar
rodH
I am trying to figure out how to make a heat sheild, do you have a pic of the one you bought???
Old Mar 5, 2004 | 11:56 AM
redls1's Avatar
redls1
Sorry dont have a pic and dont get my car back till next week.
Old Mar 5, 2004 | 11:59 AM
rodH's Avatar
rodH
can you explain what it looked like??
Old Mar 5, 2004 | 02:22 PM
Z350Lover's Avatar
Z350Lover
your car is so beautiful... nice work and nice write up!
BTW, how much did you pay for the bonnet if you don't mind me asking?
cheers,
richie
Old Mar 6, 2004 | 09:42 AM
redls1's Avatar
redls1
Just a half cone made of plastic that shield sheat from the engine so it doesnt hit the filter directly.
Attached Thumbnails CUSTOM INTAKE DONE AWESOME RESULTS W/ BLITZ HKS APEXi TRUST READ NOW WHY ITS BETTER!!-injhs5000p.jpg
Old Mar 6, 2004 | 09:50 AM
rodH's Avatar
rodH
I am thinking of making one similar to this. Here is a link to how the guy made one for his BMW.
http://www.rose-hulman.edu/~smithm3/mods/cais/
Old Sep 14, 2004 | 02:19 PM
  #38
nickelsnickels's Avatar
nickelsnickels
I am in the process of building an intake but frankly did not consider the different densities or mesh sizes of air filters. Something I am doing a little different is coating the tube (MAF) and heat sheld with a liquid ceramic coating. I have done alot of testing and the ceramic coating will decrease the tube at any temperature, and incresing the cooling effect of the metal over 50% once it exceeds 200 degrees. I don't understand why intake manufacturers have'nt taken advantageof this process. Also, I am using a used stainless steel 2-qt open container from a restaurant supply company as my heat sheild. If this works I will build a 2nd and have it ceramic power coated.
Old Sep 14, 2004 | 02:35 PM
  #39
AceJ587's Avatar
AceJ587
COMEON man! This is not a 70's DATSUN. I think your ceramic coating is a good idea, but a Restaurant supply container?
Old Sep 14, 2004 | 06:50 PM
  #40
alininger2001's Avatar
alininger2001
JWT will sell you a heat shield for $25. I hear its a pretty good one, fits perfectly with the hood.
