A little something for those worried about Kinetix plenum
I was watching the Horsepower TV Marathon today on Spike TV, and they put a performance manifold on I believe it was a chevelle. Anyway, they used gasket sealant on the new manifold, and even went so far as to recommend ALWAYS putting the gasket sealant when putting on ANY aftermarket manifold. So, for anyone worried about the quality of the Kinetix plenum strictly due to worrying about having to use sealant, DONT BE. I've attached an image of the exact sealant they used, which happens to be the same kind I used...
PS... I'm LOVING my plenum, the growl is terrific. Just today I started my car up while two hotties were walking by. They stared for a good 15 seconds as they walked away...
Fuel can get into the upper plenum. Plus some people run a nitrous wet shot which shoots fuel right in there. It does not matter what plenum you use. As for using it with ours, we send a new gasket with it. You can double up if you want to (or need to), use the new one only, or save it for later. Our official recommendation would be if the Crawford plenum does not seat due to severe warpage or shipping, send it back and it will be taken care of . . . do not use RTV to seal the plenum. I think lsdunique will agree the goal is to get it to seal without then mess, hassle, and provisional solution of RTV. If it is not sealing I think he is taking them back, that’s what I have heard from some of the people with them.
Good luck.
Good luck.
Guest
Posts: n/a
Originally posted by westpak
Yes, he didn't give it a second thought and sent me another one ASAP, great service and not issues so far with the second one.
A couple friends of mine tried the Kinetix, after a few "unfortunate" attempts they gave up - threw the one in the trash and forgot about it.
I on the other hand got a plenum.
Like the imposter, I was shipped another plenum. V2 to be exact. Works like a charm, but I did strip the threads on the long bolt near the throttle body. Popped them out of place. I need to try a bigger bolt I guess. It doesn't leak without it in place so I'll just go with it for now. Maybe use a little sealant. Damn I hate aluminum.
I stripped that bolt too. Go buy a 75mm M6 bolt and all will be well. I suggest using 1 or 2 washers since the plenum in that area makes it hard to torque it down to to contact with the wrench.
I don't think Kinetix version 2 need the rtv, since you can tighten it down a lot more than version 1. But I was using rtv when I installed version 1, and after taking the plenum off, the rtv did not stick to the bottom paper gasket. Nothing to scrap off, very clean...
Originally posted by VandyZ
RTV is not impervious to gasoline. I would recommend something else to seal an area that may come into contact with fuel.
Just a thought.
Just a thought.
.-Chris
Originally posted by Duflacci
Hmmmmmmm
Hmmmmmmm
That's bizarre!! BIZARRE I SAY!
Well, I used Ultra-Copper and I'm damned proud of it! I'd use it again if I had to! Yeah! I regret nothing... nothing at all! (at least it says it's good for import car's intake manifolds) Hehehe!
allmycarsdie
May 13, 2016 04:38 PM
