will Helix Test Pipes Throw Check engine Light?
Old Jul 18, 2004 | 06:34 PM
04evo2's Avatar
04evo2
Originally posted by G Monster
$14 from any major auto parts chain in your area. Drill out the non-fouler that the sensors attach into to 1/2" OD. Voila.
Can you draw out the steps for me alittle cause im kinda confused on how this works. Thanks!
Old Nov 22, 2004 | 06:55 PM
noguffay's Avatar
noguffay
Originally posted by Jason@Performance
the ONLY time any HIGH FLOW CAT or TEST PIPES will throw a CEL would be if the person installing them damages the O2 Sensor...
Totaly wrong!
Without a Cat to block raw gasses the O2 sensor sould always show a positive feed back. This is the reson the Cats are there in the first place and the post O2 sensors are there to tell you your Cats are failing. Hence, no cats no filtered gasses, positive feed back from post O2 sensor
My O2 sensors come on after running my car for about 3000KM after new oil change. Once I do a new oil change the idiot light gose out. hummm I wonder why?
Old Nov 22, 2004 | 07:08 PM
noguffay's Avatar
noguffay
Originally posted by time4aspliff
[ My Kinetix pipes have a weird hiss after i rev it up and the rpms come down.
I get this to. I have Stillen race pipes. I believe its the ringing sound of one the components of the exaust system. Maybe the resinator. I believe this is due to the increase in exaust presures after having removed the cats. Sometimes if there are little extra extetions of pipe metal where the welds are they will vibrate. Maybe its the compression rings (seals) between the flanges.
Old Nov 22, 2004 | 07:18 PM
noguffay's Avatar
noguffay
Originally posted by 04evo2
I just installed my stillen test pipes today and now my SES light is on. Has anyone had this light or just the CEL?
My SES came on after installing Stillen deletion pipes, (it wouldn't matter which brand we installed) After I change my oil it goes out for a while. How long depends on how I drive. The more aggessive I drive, the more the oil gets carbonized, hense the dirtier the exaust gasses and the light comes on
Old Feb 22, 2005 | 06:42 PM
amf813's Avatar
amf813
Originally posted by noguffay
Totaly wrong!
So I guess Jason conceded because he never responded.....
Well, my SES light is on and I don't think I damaged the 02 sensor. I am going to check with my local auto parts store and see if they sell an 02 Simulator.
Old Feb 22, 2005 | 09:09 PM
Z BOY's Avatar
Z BOY
die die gets the cel in his 05 z running helix tp. this friday, we are putting the stocks back on, and we'll know definitively if damaged sensor is ONLY cause of cel.
Old Feb 22, 2005 | 09:21 PM
Z BOY's Avatar
Z BOY
Originally posted by Cra Z
Im probably gonna purchase one so can u tell me where and how much its going for ?
pm sent.
Old Feb 23, 2005 | 09:49 AM
DrVolkl's Avatar
DrVolkl
Totaly wrong!
I wonder why I've had my Kinetix resonated test pipes on since last July and have never had a SES light?
Maybe you're burning oil ???
There is obviously no pattern at this point. Perhaps its the year (I have an '02 build), perhaps it is the brand after all...perhaps it's just luck and mine will throw one tongiht...who knows. I do know that 02 sensors are pretty sensitive and you have to be careful...some people may be burning theirs out...
Old Feb 23, 2005 | 01:22 PM
Z BOY's Avatar
Z BOY
maybe 02 sensors are like women...nuff said?
Old Feb 23, 2005 | 02:34 PM
DrVolkl's Avatar
DrVolkl
Definitely.
Old Feb 23, 2005 | 05:56 PM
DIE DIE's Avatar
DIE DIE
WRONG!!!!!!!!! I got my helix TP on and got no CEL for 3 days, then BAM!! It came on.. Now I can reset my ECU, and the CEL stays off for a few days then comes back....Nothing is wrong with my o2 censor..
Old Feb 26, 2005 | 11:53 AM
DIYZ's Avatar
DIYZ
DIE DIE's situation is tottaly normal.
I do burn a little more than normal amout of oil, mostly due to my driving style, and it does cause the O2 sensor indicator to come on. I've tested this theory by reducing my oil consuption (through less agressive driving) and the light does not come on.
Old Feb 26, 2005 | 06:03 PM
Z BOY's Avatar
Z BOY
Well, last nite die die and i reinstalld his stock cats. he has since driven 170 miles without the cel, so we proved that damaged 02 sensors are NOT the ONLY cause of the cel coming on.
Old Mar 7, 2005 | 05:41 PM
CajunZ's Avatar
CajunZ
Default crawford cats
I'm about to install Crawford Cats and injen exhaust should I be worried about any lights coming on ?
Old Mar 13, 2005 | 07:26 AM
amf813's Avatar
amf813
Whenever I reset my ECU the SES light turns off. The light never comes back on until I really drive agressively (usually around 4500-6000 rpm shifting).
etkms
Jun 19, 2022 06:30 PM
JjL
East Canada
Jun 12, 2019 03:04 AM
350z_z33.
Jul 3, 2017 04:01 AM
_koubie_
Sep 20, 2015 06:34 PM
