Pop Charger and Waranty...?
Old Apr 6, 2004 | 07:09 AM
MadneZz's Avatar
MadneZz
Default Pop Charger and Waranty...?
Hi,
I just install the pop charger, it ran fine.
but a day later I'm having this same problem I had before.
It boggg big time around 3000 RPM. I had this problem before, it only laster a little while. The dealer cant find anything wrong with it since it didnt happen when they tested it.
I need to take this back to the dealer, but should I put the stock intake back? I dont want them to claim that the intake is causing the problem.
Thanks
HL
Old Apr 6, 2004 | 07:37 AM
DiRN's Avatar
DiRN
Since you don't know what the cause of your problem is, I would put the stock intake back in. It never hurts to be extra careful.
Old Apr 6, 2004 | 08:32 AM
BrickydZ's Avatar
BrickydZ
Put the stock intake back on to see what the problem is.
This is not being false. Yyou need to rule out in your own mind whether the problem is related to the pop charger or not. When reinstalled, you can diagnose the problem. If it still persists it wasnt the pop charger and you have in no way caused the problem.
If on the other hand it was the pop charger install then you will know it right away.
I am not sure what "BOGGG" means but your first place to look for problems might be the "MAF" the air flow sensor. If it is out or misinstalled can cause lot of problems.
Good Luck.
Old Apr 6, 2004 | 03:28 PM
MadneZz's Avatar
MadneZz
Thanks for reply..
Well I went home at lunch.. took it out and brought it to the dealer. So far, they think it's the MAF sensor, but they are going to reprogram the ECU also. Beacuse the heck engine light did not came up when the car is not runing right.
07ZEKE
Aug 23, 2021 09:15 PM
kyin
Oct 15, 2015 05:54 AM
B Esquire
Sep 24, 2015 07:52 AM
