Question about Kinetix Plenum with Mods?
Old Apr 10, 2004 | 08:01 AM
Blownaway's Avatar
Blownaway
Default Question about Kinetix Plenum with Mods?
Sorry to beat a dead horse, but I cant find it.
Here is my setup. I am wondering if I will be making too much power to run the Kinetix plenum.
AEM Polished Cold Air Intake
Crawford Headers
Futjisubo Y pipe
HKS Grounding kit (black)
JIC Magic Exhaust
JWT Lightened Flywheel
JWT Titanium valve springs and retainers
Mines Test Pipes
Tomei 268 Cams
ZEX 75RWHP Wet Kit
Also does anyone have the JIC Carbon Strut bar and will the plenum fit under it?
Thanks in advance. The cam install is today. I will post some pictures later...
Old Apr 10, 2004 | 09:06 AM
JST4FN's Avatar
JST4FN
I'm not sure what you mean by making to much power, but if you have a lean backfire with the nitrous on you will destroy it and your hood, so keep that in mind. As far as the plenum goes I like mine and although the power is hard to feel you definitely notice that it breathes better in the upper rpms because it doesn't fall off like the stock plenum. I'd buy it again if that helps.
Thanks Mike
Old Apr 10, 2004 | 09:34 AM
PhoenixINX's Avatar
PhoenixINX
Dunno bout the Kinetix, but talk to mjedens... that is basically the setup he's been running for awhile... except he's moving his 150 shot to a 250.
He loves his Crawford Plenum!
Old Apr 10, 2004 | 10:50 AM
SungNamZ's Avatar
SungNamZ
Search is down, so you can't check, but I think I can remember seeing that having the JIC Strut Bar will not allow you to use the Kinetix Plenum. Perhaps someone else will respond.
Old Apr 10, 2004 | 11:05 AM
12SecZ's Avatar
12SecZ
I am unclear on whether this plenum will run on N20, I know mine does (Crawford.)
I asked this too and was told it was only N/A and they are making another one for FI. So the gray area is does it due N20?
You say you want to do a 75 shot but keep in mind it never ends there ha-ha!
Old Apr 10, 2004 | 11:06 AM
lowrider's Avatar
lowrider
Hey Chris
What's with all those strikes? You playin' with someone's mind?
I believe SungNamZ is correct. The only strut bar that will work with the Kinetix is the Stock one, and of course the Crawford Bar.
Lou
Old Apr 10, 2004 | 11:13 AM
Blownaway's Avatar
Blownaway
Thanks boys, if anyone else has something to add I am all ears....
Old Apr 10, 2004 | 06:38 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
only stock stb will fit with the Kinetix plenum. like others have said, if you run into backfire, then the plenum will probably not be able to handle it. this has not been tested yet...
Old Apr 10, 2004 | 07:27 PM
PhoenixINX's Avatar
PhoenixINX
Originally posted by lowrider
Hey Chris
Lou
Lou...
Proudly earned the first strike.
Doug and Victor though the second would be a good April fools...
So I said, what the hell... asked Victor how many can he fit... since I'm such an a$$ he was going to have to put them there eventually!
issyz
Jul 2, 2017 03:04 PM
Dymsi
Sep 29, 2015 11:32 AM
codek
Sep 28, 2015 03:03 AM
Tochigi_236
Sep 27, 2015 03:40 PM
