Interesting pop-charger observation
Old Apr 27, 2004 | 12:31 PM
  #41
Road Warrior's Avatar
Road Warrior
forgot to mention....while your up grab me another cold one
Old Apr 27, 2004 | 12:45 PM
  #42
SEzzz's Avatar
SEzzz
does the pop charger really change the sound that much?
Old Apr 27, 2004 | 10:04 PM
  #43
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally posted by jng1226
I agree with Road Warrior, who is supporting your point, BriGuyMax. I was also agreeing with you in principle that the practical results of the mod, what I believe you call "real world" are what matters most when evaluating the effectiveness of a so-called power mod.
The debate over intakes has raged seemingly forever and I have never seen an empirical test done like the one I describe. My opinion is that this would give the most scientific answer based on "real world" results. I simply disagree with your example of comparing your car to another as a definitive answer to what mod is better, for the reasons I stated.
Bottom line, I actually agree with you, just not what you said. Until someone does the test that I described, or something similarly methodical, we'll never really know and this debate will keep flaring up.
Resume flames!
No more flaming required
I really didn't want to start this debate again...but I guess it happened anyway...
Old Apr 27, 2004 | 10:05 PM
  #44
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
yes....the car really screams above 5000rpms at full throttle...
Old Apr 28, 2004 | 01:34 PM
  #45
SEzzz's Avatar
SEzzz
i think i'm gonna have to get me one
how much did everyone pay?
Old Apr 28, 2004 | 02:40 PM
  #46
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
100 bucks from UltimateZ....
Old Apr 28, 2004 | 03:34 PM
  #47
Wedge's Avatar
Wedge
This is an interesting thread. Yes, it is sort of a rehash, but a year ago absolutely no one wanted a Pop Charger. Everyone kept talking about the "hot air" under the hood, etc and that the AEM or Injen CAI was the only way to go. I read a couple of obscure articlea on the Pop Charger, as well as on Jim Wolf Technologies and opted for the Pop Charger. Most people thought I was an idiot when I posted that I had purchased one.
Things have swung around now and the Pop Charger seems to be the weapon of choice for a ton of people. Some are replacing the much more expensive CAI's they bought last year with the Pop Charger. I suppose this is due to the dyno results shown as well as the relatively low cost.
Yesterday, I went to TechnoSquare to have my ECU reflashed. I had met Tadashi several times in the past at different meets and while he was checking my car over and doing the reflash, we talked about differnent modifications.
It was over 100 degrees here is Southern California yesterday, and I had been in a few traffic jams along the way.........my engine bay was VERY hot when he popped the hood. My Pop Charger was also very hot. You couldn't touch the metal parts of the filter without burning yourself. My engine temp gauge never got past the center position though.
Tadashi and TechnoSquare know the Z inside and out. Many people send their cars there to be refitted for racing. They were building a race car yesterday in fact.
When we talked about intakes, he said that they always use the stock airbox with a K&N filter. He said that it is true that the Pop Charger shows gains on a dyno, but that in racing conditions the stock box performs better. He also said if you have a show car, of course a good looking CAI makes the engine bay a lot nicer. If you like the sound you get, but don't mind a little less power when you are moving quickly down the road, get a Pop Charger.
Of course my jaw was dropping at this point....since I was one of the first Pop Charger advocates. He went on to explain that everyone forgets the fact that the stock box was designed to become pressurized while the car is moving. This pressurization is something that the engine was designed to run best with. Don't ask me the engineering reasons for this.........I decided to take him at his word since he has seen a thousand times more Z's than I have. Maybe with pressurization the air flow is more steady and smooth in case your speed is varying at all......who knows?
The other reason my engine was hot according to Tadashi was because of my K&G after market grille. He looked at it and immediately said it was "restrictive". I sort of figured that.....even a screen door limits the amount of breeze coming in. There are only three horizontal bars angled in the right direction on purpose on our 350's. They were designed for airflow........not looks (that's for sure). The bottom of the engine compartment is sealed, so air can't simply bypass the aftermarket blockage and get in. I took off the grille last night and went back to the old stand by.......the door edge molding........(I really liked that K&G grille too)
Anyhow, I haven't made up my mind yet about putting the stock air box back on.........I really like the sound of that Pop Charger, RT CAT and Borla combo. (yes, it looked like I was running a bit lean before the reflash.....I had cooler plugs put in since the others were a tad "roasted") Since I invested so much in "air flow" mods, I guess I did mess up putting on a grille that restricted air flow.......but it sure looked nice.....lol
Old Apr 28, 2004 | 03:48 PM
  #48
flynnibus's Avatar
flynnibus
Z Flier
The 'dyno' results about the pop-charger are simply one magazine article (forget the name right now) which claimed 6.5hp for the popcharger and magically over night it was accepted as fact. I don't think I've seen any other dynos with just a Popcharger. Most of the dynos related to it were when the car first came out.. because the JWT was one of the first 'performance' mods available. The heat shield add-on came later.
The crawford crew also talks about the stock box running pressurized.
Honestly, I have my own opinion on that topic purely based on the size of the areas involved.. but I'll keep it to myself.
Old Apr 28, 2004 | 03:58 PM
  #49
Sins4u33's Avatar
Sins4u33
Originally posted by rodH
btw, why is someone with a 5AT so interested in racing??
i've got a 5AT and im very interested in racing...i dont see the problem...even with my 5AT after i get my torque converter i will be shifting faster than any human being can....i dont see the problem...you MT people always knocking on us...i got my AT because i found the best price i had ever seen for a touring model fully loaded....i dont mind taking **** from people but if they understood what an auto could do...i can do just about the same things a manual could do....i mean right now i wish i had that kick when i shifted gears but i dont and i made the choice to buy the AT...once i get my torque converter it should feel closer to a manual....also i know how to drive manual that wasn't the reason i got the AT
sorry to get off topic also...the pop charger is amazing im glad you like it, for the money its the best buy i beleive.
Ben
Old Apr 28, 2004 | 04:02 PM
  #50
Sins4u33's Avatar
Sins4u33
yes it does!! ive got a video of me doing donuts in some school parking lot in lancaster county PA heres the link
https://my350z.com/forum/showthread....threadid=68756
this is with just the intake! stock exhaust! only mod is intake enjoy!
Ben
Old Apr 28, 2004 | 05:10 PM
  #51
jng1226's Avatar
jng1226
When we talked about intakes, he said that they always use the stock airbox with a K&N filter. [/B]
Wedge, that was extremely informative for me, thanks a bunch! TS is definitely an opinion to be respected.
On another note, I'm really glad to see you're OK, I thought for sure you were a goner when you and Luke assaulted that Imperial Walker. When it crushed your crash-landed Snowspeeder, I thought I would never hear from you again. Long live the Rebellion!
Wow, was that geeky or what?
Old Apr 28, 2004 | 06:12 PM
  #52
Wedge's Avatar
Wedge
lol jng1226........I don't know about the geeky thing......who doesn't like star wars? But no.......that is not where the nick came from. and not golf either........it is an old nickname from long, long ago when I played high school football on a planet far, far away.
It was a very interesting day at Technosquare.....I learned a lot.
Old Apr 28, 2004 | 06:23 PM
  #53
phile's Avatar
phile
So basically we're trading cool sound for a performance loss. Awesome. Oh wait, no.
Wedge, with all your mods, it's ok to keep the pop-charger on. You're already above your baseline hp/tq i'm assuming. So why not stay with the pop-charger? The real question now is, how much would you gain if you put the stock box back on?
Old Apr 28, 2004 | 06:55 PM
  #54
Wedge's Avatar
Wedge
good points phile........I will probably just stay with the pop charger. I don't race anyhow.......and I do like the sound....a lot.
Old Apr 28, 2004 | 07:54 PM
  #55
UsafaRice's Avatar
UsafaRice
Geek on-
Bah, Wedge was Luke's wingman (or Luke was his) and Wedge's backseater was Jansen...
-Geek off
Anyway, Sins, I certainly understand ATs and how useful they are for bracket racing or say, ridiculously high powered cars like Top Fuelers (different setup of course, but not manuals)!!
Perhaps RodH is talking about road racing (unlikely...)
Old Aug 27, 2004 | 12:08 AM
  #56
NOBI's Avatar
NOBI
if you are worried about getting more cold air to the port by the intake, simply remove the plastic piece on that side of the grille. it really doesent serve a purpose. (instant 50 whp gain DYNO PROVEN!!!) oh yea and it lightens the car too.
Old Aug 27, 2004 | 08:55 AM
  #57
MRfire's Avatar
MRfire
WTF??
Attached Thumbnails Interesting pop-charger observation-howtospotarichguy1.jpg
Old Aug 27, 2004 | 01:05 PM
  #58
ZinMiami's Avatar
ZinMiami
Well the post above by Wedge just helped me make up my mind. I had a previous car that everyone kept saying already had an efficient intake system. But of course I put in an AEM CAI. It was pretty and sounded great, but actually lost power in the low and mid range, despite what AEM claimed.
So this time I decided I would really research before putting one in the Z. I stood and stared at the stock intake, took temp readings after a day of my typical road conditions. It is actually cooler to the touch than any CAI tube thats for sure. So heat soak is not an issue. The pipe is of good diameter and is basically a staright thru to the TB. The air inlet at the front gives it access to cool air when in motion. So I say to my self, "self, just what are you trying to fix here?"
I will take TS's advice and keep the stock airbox but put in a K&N filter. I was looking at the Nismo element but I can't imagine what makes it worth $80 versus $40 for the K&N.
Thanks for that write up Wedge. You just saved me a bunch of $$$.
Old Aug 27, 2004 | 06:13 PM
  #59
NOBI's Avatar
NOBI
the stock airbox is what they run in sages spec z (race car), and their researchg proved it does get the coldest air. but to tell you the truth i wouldent trade my pop for anything, the sound alone is worth the few degrees... and if you are that concerned about a few degrees id say shell out for the stillen air box, that box mixed with the ported bumper would allow the ram air to work to it full potential. but yes i agree with ZinMiami that stock for cold air cant be beaten.
Alexreyes
Sep 30, 2015 11:30 PM
