Something to keep the ECU happy about testpipes
Old Nov 7, 2004 | 10:59 AM
Poizon's Avatar
Poizon
Are you still selling the set up please let me know I will pay you immediately. thanks! Dan
Old Nov 24, 2004 | 07:39 PM
noguffay's Avatar
noguffay
I've go a 2003 350Z NA and have had Stillen race pipes for about 10,000KM. My light came on a little after installing the pipes. Everytime I do an oil change the light goes out for about 3000KM then comes back on. It depends on how agressive I drive in that period which in turn affects the time it take for the SES lifht to come back on. I suspect this is related to fouling of the oil. I've seen this 555 timer simulator before, and wasen't shour if it would work for our 350Zs. Now that you've proven this to work I'll try it myself. Thacks for the info everyone.
PS. If some peoples SES lights are not coming on after removing the O2 sensors something must be wrong about your ECUs or extremly right about your engines. Maybe your cars are burning gass very efficiantly and/or very little oil. My car burns more oil the more aggessive I drive. I'm testing two therorys, I've decided to drive very mildly for the next oil change duration reducing my RPM/Oil PSI to see how much this affects my oil consumption and O2 SES indication.
Old Nov 24, 2004 | 08:44 PM
Poizon's Avatar
Poizon
Please order this ecu tranquilizer! We need enough orders to make it worth his while; he has to go and get the parts, and then put them together.
Old Nov 25, 2004 | 11:25 AM
Poizon's Avatar
Poizon
Please reply to this thread.
Old Nov 28, 2004 | 02:56 AM
Ep3's Avatar
Ep3
i used to have a honda EP3 (2002 si) i just got an 05 Z but with the Si if you put high flo cats or straight pipes the CEL light is gaurenteed... and a 02 sim i put because i heard it if you run the car with the CEL light on The ECU will cause the car to run lean i know its not a Z but hope it helps
Old Nov 30, 2004 | 02:13 PM
Gman2004's Avatar
Gman2004
Originally posted by tonylittell
got a 04 with xerd pipes and had a light since about 80 miles after i had installed
I have an 04 G35 coupe and my light came on shortly after installing my pipes. Just currious to see if everyone that said their light did not turn on have 2003's......Wondering if it might have something to do with the ULEV2 ECU?????
Old Dec 2, 2004 | 06:38 PM
noguffay's Avatar
noguffay
I have an 03 Z and my light came on after installing my pipes. This is what should happen when there is no cat to clean the exhaust gasses. Maybe the sensitivity of each car is a little different, maybe the gas burning efficiency of each car is a little different, maybe the oil consuption of each car is a little different, but the light should come on if there is no cat.....period. I just built an O2 sensor simulator, build one or get one, it works.
By the way my light goes out after each oil change. ie. clean oil...........cleaner exhaust gasses. It came on again after a few thousand kms. The last time I've changed my oil and it hasen't come on yet, I've reduced my agressive driving to see how long it will take to come back on. (I've disconnected the simulator)
Old Dec 2, 2004 | 06:45 PM
Gman2004's Avatar
Gman2004
So does the o2 sim work or not??? You say the light turns on and off. Was this before the o2 sims?
Old Dec 2, 2004 | 08:24 PM
Methane's Avatar
Methane
Im pretty sure only those with 2004.5+ ECU's will trip the CEL light with test pipes. i know plenty of 03's with test pipes that have not thrown any lights yet.
Old Dec 2, 2004 | 08:43 PM
002-M-P's Avatar
002-M-P
Does anybody have a pic of these simulators themselves? I would like to try and build this myself and would like a pic to base this off of.
Old Dec 3, 2004 | 06:23 PM
noguffay's Avatar
noguffay
It works great, It was before the sim that the SES light would come after a while and go off after a fresh oil change, but I've disconnected the sim to see if my driving style has an effect on the duration ( and oil consumption) for which the SES light would stay off.
Old Dec 3, 2004 | 06:27 PM
noguffay's Avatar
noguffay
I'm not aware of the CEL light but I knowk for sure my SES light came on after installing my pipes and goes off after a fresh oil change, and will stay off if I use my SIM.
Old Dec 3, 2004 | 06:30 PM
noguffay's Avatar
noguffay
http://www.mkiv.com/techarticles/ox...nsor_simulator/
Start from the top of this thread and you will find more info on this subject
Old Dec 3, 2004 | 08:01 PM
metalz's Avatar
metalz
are there any drawbacks to now having your CEL available to you...sorry if I am repeating a question
Old Dec 5, 2004 | 08:56 AM
Poizon's Avatar
Poizon
Will this work on 2004 Z
Old Dec 5, 2004 | 12:47 PM
noguffay's Avatar
noguffay
If you mean the SIS? If it ( the ECU) requiring the same oscillating signal it should work. I'd just try it, it can't hurt, and if doesn't work you've only spent like 20 bucks
Old Dec 6, 2004 | 05:16 AM
Juztin's Avatar
Juztin
Awsome, thanks for the details sk.
Old Jan 13, 2005 | 09:32 AM
  #38
1sickZ's Avatar
1sickZ
Default Has anyone put these on an 04 350
I may need something like this. Not sure havent put my test pipes on yet so I would like to do this before hand so I dont get a check engine.
Old Mar 3, 2005 | 02:42 PM
  #39
marcelz's Avatar
marcelz
do you still selling the simulator???
Old Mar 3, 2005 | 03:27 PM
  #40
Zivman's Avatar
Zivman
Link
What more do you need to know?
