Want to get rid of the SES light from removing your cats?
Old Feb 6, 2005 | 08:34 PM
Zivman's Avatar
Zivman
Default Want to get rid of the SES light from removing your cats?
I have been getting some PMs in regards to MIL eliminators and getting rid of the SES light due to testpipes and the removal of the stock cats. So, here are a couple options that I know have been successful on other cars and are cheap and easy to install:
MIL Eliminators:
Here's a LINK to where I get mine.
I have used them on other cars of mine, but haven't driven them installed on the Z yet, but I am 99% confident they work.
Follow the intall for the ford vehicles that comes with the set as the wiring for our o2 sensors are the same.
If you don't want to cut/splice wires, here is another option to trick the ECU that I picked up from my MSP buddy's website:
LINK
Shortened version:
"i just went and got the HELP! Spark plug non fouler. Part 42002 for 3.99 from autozone.
Its a 2 pack, that you screw together, and then screw the open end into the o2, and the other into the bung.
I'm going to be getting this done tomorrow.
This does require that you drill out the hole to allow for more flow to the o2, but thats pretty easy."
Old Feb 9, 2005 | 10:16 AM
wfcall's Avatar
wfcall
Default Re: Want to get rid of the SES light from removing your cats?
Does anyone know if any of these methods work on the LEV ecu's on the o4's. supposedly the ECU parameters are much tighter than the 03 ECU and very picky about what signal is coming bact to the ECU from the rear o2's
I've got an 04 with headers/testpipes/and injen ses and it has ALWAYS had the 02 sensor low threshold since installing the test pipes and it comes back within minutes of being reset if not sooner.
Old Feb 9, 2005 | 10:46 AM
Zivman's Avatar
Zivman
Default Re: Re: Want to get rid of the SES light from removing your cats?
I haven't driven on them yet and won't until mid to late march, due to storage/winter. I have been running them on my stratus coupe for over 2 years without one SES light, and my good friend runs them on his mazdaspeed protege for about 12K miles without a single SES light.
When I get my throttle body back, I will start the my car and pull it into the driveway and run my datalogger and get the readings off the o2s to ensure they are working correctly. I should have my throttle body back later this week
Since I already wired my o2 sensors I would like someone to try the HELP! method. It is very simple. Get two HELP! Spark plug non foulers for each side, drill the holes on them to atleast 1/2" screw them together in the o2 bng and reinstall them. If I hadn't already wired mine, I would give it a shot.
I am 99.9% confident in the MIL eliminators, but 50/50 on the HELP method as I don't have first hand experience with it. I wouldn't worry about the LEV ecu's as I have used these eliminators on cars with pickier ECUs.
Old Feb 9, 2005 | 06:57 PM
wfcall's Avatar
wfcall
Default Re: Re: Re: Want to get rid of the SES light from removing your cats?
Thanks, more than likely i am going to try the HELP method just to satisfy my curiosity.
Old Feb 9, 2005 | 07:42 PM
Z BOY's Avatar
Z BOY
Default Re: Re: Re: Re: Want to get rid of the SES light from removing your cats?
pls take and post pix!
Old Feb 10, 2005 | 09:25 PM
wfcall's Avatar
wfcall
Default Re: Re: Re: Re: Re: Want to get rid of the SES light from removing your cats?
I bought the anti-foulers today so Prob. this weekend I'll getit done and give y'all an update.
Do you think the hole to be drilled should be a tight fit around the "stem" of the sensor or should it be big enough to allow the upper portion to "breath" the exhaust as well? How to wasn't real clear on this.
Old Feb 11, 2005 | 05:13 AM
Zivman's Avatar
Zivman
Default Re: Re: Re: Re: Re: Re: Want to get rid of the SES light from removing your cats?
1/2"
use the 18mm ones and just drill out the bottom of one of them with a 1/2" drill bit (do not cut it off) and screw them into each other. it creates a chamber outside the main exhaust fow for the o2 to get a proper reading. suby guys have been doing this for a while with no cel/mil.
Old Feb 11, 2005 | 06:07 AM
FairladyZ's Avatar
FairladyZ
What year is your car? I have an 03 and my lights never went off. I wonder why the 04-05's go off?
Old Feb 11, 2005 | 06:23 AM
Zivman's Avatar
Zivman
I have an 04.5 june or july '04 build date. The reasons that the newer cars throw codes is because the ECU is more sensitve to the o2 readings. they are supposed to be more emissions sensitive.
Old Feb 11, 2005 | 12:21 PM
FairladyZ's Avatar
FairladyZ
Old Feb 11, 2005 | 01:43 PM
Zivman's Avatar
Zivman
update on MIL eliminators:
Got my throttle body back from proflow and got the car back together again. sat and watched the readings from the rears and the MIL eliminators are definitely working. They are reading consitantly lower than the upstream sensors which is what I wanted to see. I still haven't driven on them yet, but I have enough experience with o2 sensors to know they work based on what I saw with the car running.
Old Feb 11, 2005 | 09:11 PM
basam350z's Avatar
basam350z
I have a question. Are these eliminaotrs changing the voltage readings that are sent to the ECU? If so, won't this mess with what the ecu thinks is the current a/f ratio and change the ration in an adverse way?
Old Feb 11, 2005 | 09:43 PM
baileyrx's Avatar
baileyrx
no, the ecu uses sensors IN the engine. the cat sensors are to let you & whoever else might care that your cats might not be working properly.
Old Feb 12, 2005 | 07:59 PM
Slip and Slide's Avatar
Slip and Slide
If the cel light does come on it is more or less a idiot light letting us know that somethings isn't correct emmisions wise. But does this effect the performance of the car as well?
Old Feb 13, 2005 | 06:15 AM
Zivman's Avatar
Zivman
On some cars it does affect A/F ratios slightly as the ECU will attempt to heat of the catalyst by adjusting the A/F ratio at times, but most like it doesn't do anything other than indicate the cats are gone/not working.
Old Feb 13, 2005 | 03:47 PM
wfcall's Avatar
wfcall
On the Z the second o2 sensor doesn't do anything for A/F control; it just reports on the performance of the cats. The first o2 sensor is the one that gives feedback to the ECU to help manage A/F
Old Feb 13, 2005 | 03:55 PM
wfcall's Avatar
wfcall
Did the help method last night...took it out and drove the crap out iof it and everything else I could do that used to make it turn on...so far no cel
Old Feb 13, 2005 | 04:21 PM
Zivman's Avatar
Zivman
Default Re: Re: Re: Re: Re: Re: Re: Want to get rid of the SES light from removing your cats?
awesome, good to hear
Old Feb 13, 2005 | 06:49 PM
Slip and Slide
excuse my ignorance but I'm still not quite clear on which route to go.
Old Feb 13, 2005 | 06:52 PM
PhoenixINX's Avatar
PhoenixINX
Same here... sounds like a newer ECU revision. Yuck.
