painting kinetix plenum
Old May 25, 2004 | 07:16 PM
jun14scr's Avatar
jun14scr
Default painting kinetix plenum
has anybody painted their kinetix plenum with high temp. engine paint? if so, how did it turn out!? i can't stand how ugly the matt black piece looks.. thinknig about painting it a gloss black.
Old May 25, 2004 | 07:26 PM
ares's Avatar
ares
Veteran
there was a thread, one was painted by a member/painter, another by just a DIY guy. they both turned out cool. the professional job looked incredable.
Old May 25, 2004 | 07:41 PM
pimp1911's Avatar
pimp1911
Zpresence has painted the kinetix plenum. He is over on 350zfrenzy.com. Nice professional job using high temp paint.
Old May 25, 2004 | 07:47 PM
chazzg's Avatar
chazzg
Chrome baby
Old May 25, 2004 | 07:49 PM
chazzg's Avatar
chazzg
Old May 25, 2004 | 09:22 PM
all_bark's Avatar
all_bark
chazzg, lets see that one on the car!
Old May 26, 2004 | 02:57 AM
Z CRUZN's Avatar
Z CRUZN
Default Painted Kinetix.........
Rob (ZPRESENCE on 350ZFrenzy.com) actually scrapped the idea of the "chrome" paint on the Kinetix plenum - the mirrachrome paint did not end up adhering very well on the surface of the plenum due to the oil content of the plastic used - would never totally dry and he wasn't satisfied with the finish. He stripped the Mirrachrome and re-did it in high black gloss. Here's a shot of the finished black.............
Old May 26, 2004 | 03:08 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Default Re: Painted Kinetix.........
That's because you have to wipe your plenum down with paint thinner before you paint it. I couldn't even get the tape to stick while trying to tape it off before I wiped it down.
Old May 26, 2004 | 05:29 AM
350ZRB's Avatar
350ZRB
Default Re: Re: Painted Kinetix.........
Do you think that the new Kryon Fusion spray paint (specially made to work on plastic) work on Kinetix plenum?
About $5 a can, cheap.
Old May 26, 2004 | 06:02 AM
Z CRUZN's Avatar
Z CRUZN
Default Paint..........
Nope - wiping down wasn't the problem with the Mirrachrome paint...it was the makeup of the paint itself - continually "drew" the oils out of the material. Standard hi-temp paint, etc. seems to work fine (as you can see from the above post & pic). You can check with the painter himself on this: ZPRESENCE on 350Zfrenzy.com. A true professional, he worked on the plenum with the Mirrachrome for several weeks and had several problems due to the makeup of the paint.
Old May 26, 2004 | 11:25 AM
bwzabodyn's Avatar
bwzabodyn
anyone know how much he would charge to paint the plenum that gloss black? or what kind of paint and process he uses to get that result?
Old May 26, 2004 | 11:43 AM
ChrisMCagle's Avatar
ChrisMCagle
I'm thinking about painting my V3 to match my Engine covers (Red). Although that chrome looks pretty sweet.
Hmmmmm.... decisions decisions.
Old May 26, 2004 | 01:42 PM
jckolnturn's Avatar
jckolnturn
I'm can't see how the paint will stay on those V2's without cracking. The v2's flex...alot. I like the look but even the V3 has some flex.
Old May 26, 2004 | 01:49 PM
ChrisMCagle
The amount of flex is minimal. I don't think it would be a problem.
Old May 26, 2004 | 03:39 PM
jun14scr's Avatar
jun14scr
man, that black does look good. did he use a air gun?
i hope i can get that type of finish with just high temp spray paint. do u know how he masked off the letters? that looks tight.
Old May 26, 2004 | 04:56 PM
Demolition Man's Avatar
Demolition Man
i don't think you would have to mask off the letters. just paint the high temp into a cup or bowl, and then brush it on. i do it all the time with models, though a model is really different from a car. however, the paint would probably work brushed on too
Rev_Night
Nov 7, 2020 06:00 PM
350Z_Al
Oct 29, 2020 07:44 PM
Cashwin
Oct 1, 2015 06:36 AM
