AEM wideband with kinetix cats?
Old May 27, 2004 | 11:20 PM
TD30's Avatar
TD30
Question AEM wideband with kinetix cats?
The vortech is going on soon, so I will need to find a way to hook up the AEM wideband sensor to my Kinetix high flow cats. I understand the sensor needs to be in front of the cat material. Has anyone done this? Is there room for the extra bung? It looks like it would be really tight. My other options are test pipes (raspy sound) or back to the stock cats (low flow). Any suggestions?
Old May 28, 2004 | 01:55 AM
baptist's Avatar
baptist
Default Re: AEM wideband with kinetix cats?
I mounted my AEM sensor upstream of my kinetix cats. Not a problem and easy to do.
Just as a side note, are you connecting the brace across your cats, as it ripped the bracket off my cats leaving a hole in the side!
I believe Kinetix now have a fix for this that involves a pad of metal that the bracket is welded onto to distribute the load.
I have a picture of my sensor, but need to shrink it as it is too large.
Old May 28, 2004 | 02:07 AM
TD30's Avatar
TD30
Default Re: Re: AEM wideband with kinetix cats?
No, I took off the bracket when I saw your post about your cats cracking. I would really appreciate you posting a pic of the cat with the new sensor on it. Thanks.
Old May 28, 2004 | 05:55 AM
zimbo's Avatar
zimbo
Take the gauge sensor to a muffler shop and they can weld a bung hole for it.
--Steve
Old May 28, 2004 | 06:47 AM
teh215's Avatar
teh215
--Steve
Call me juvenile but I still cannot help but chuckle when I see the phrase "weld a bung hole".
Old May 28, 2004 | 02:57 PM
TD30's Avatar
TD30
--Steve
So IT WILL FIT then? Is this your setup? It seems like there is only about 1" between where the cat ends and the bolt flange. Plus, according to AEM's instructions, it needs to be mounted greater that 10 degrees from horizantal. Thanks.
Old May 28, 2004 | 03:22 PM
baptist's Avatar
baptist
TD30 you have PM
Old Jun 3, 2004 | 10:16 PM
TD30's Avatar
TD30
TD30 you have PM
Hey baptist, I sent you my email in a PM. If you could send that pic, it would be great. I will start the install Saturday!
Old Jun 3, 2004 | 10:20 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
you just need to weld the bung just below the 3 bolt flange...
any muffler shop can do it for you...
http://www.performancenissanparts.co...roducts_id=339
Old Jun 4, 2004 | 08:13 AM
baptist's Avatar
baptist
TD, sorry about the delay, picture has been sent!
AbrasiveRaysive
Sep 20, 2021 02:29 PM
sales@czp
Sep 23, 2019 03:30 PM
Li1ag
Sep 28, 2015 02:07 PM
