Help with popcharger install
Old Jun 11, 2004 | 11:04 AM
robes's Avatar
robes
Default Help with popcharger install
I have been trying to install my popcharger today and I've run into a bit of a problem. 2 of the 4 10mm bolts that connect the stock air box to the maf sensor won't come loose, I can't move them with my hands and the power drill I have starts to smoke when I use it on these two bolts. I was hoping some of you guys might have some tricks to help loosen the bolts so I can get them off.
Old Jun 11, 2004 | 11:27 AM
Alang's Avatar
Alang
WD40, and use hand tools. Drills (unless its an air wrench) don't really give you much torque.
Spray liberally with WD40, and let it sit for a while. Try tapping the bolt heads with a hammer to loosen them up.
Old Jun 11, 2004 | 02:34 PM
alphared's Avatar
alphared
Use a wrench/ratchet. Power drill don't have enough Torque to remove it. Might be possible to use the stock 10mm wrench in the trunk next to the jack.
Old Jun 11, 2004 | 04:21 PM
raidersfan's Avatar
raidersfan
get rid of the fischer pricer wrench and get a quality drill like dewalt (not the home depot **** version) on makita. just kidding, but you should have no problem breaking the loose, just dont strip the heads. you could also take you phillips bit out of your drill if it is a real small one and put it in a 1/4 socket on a 1/4 or 3/8 ratchet, should come off 1,2,3
Old Jun 11, 2004 | 04:31 PM
robes's Avatar
robes
Thanks, that worked.
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
