Need your help...pop charger
Old Jun 16, 2004 | 08:26 PM
tiggerpooh's Avatar
tiggerpooh
Default Need your help...pop charger
so i was installing the pop charger but have decided to quit....i'll need a shop or someone to finish it for me.....
so my question is can i drive my car???.....cuz i have already taken the oem filter and all the plastic piece out...so do i have to put everything back together before driving off to get it install
thanx
Old Jun 16, 2004 | 08:52 PM
groovytang's Avatar
groovytang
i installed it today, and i'm having some problems, see my thread, "popcharger help wtf" , i wouldn't drive it without a filter
Old Jun 16, 2004 | 09:40 PM
Z8M's Avatar
Z8M
Default Re: Need your help...pop charger
thanx
Why did you quit ? How far did you get ? The installation is very easy. If you can describe exactly what you've done so far, somebody here can walk you thought this.
No I wouldn't drive the car without the filter and the MAF in place. That is just asking for trouble.
Old Jun 16, 2004 | 10:39 PM
rockinar's Avatar
rockinar
thanx
YES!!!!!
Old Jun 17, 2004 | 06:54 AM
tiggerpooh's Avatar
tiggerpooh
i got the oem filter (the whole plastic part thing) off....drilled the two holes.....and was in the process of putting in the heat shield....but i'm having problem screwing that same two screws into it....it's so small in there.....i dunno...just having trouble with it....
also im just concern about how the heck am i going to tighten that last bolt....the one in the bottom....i already had a hard time taken it off...so how can i tighten it to make sure it's secure
Old Jun 17, 2004 | 07:38 AM
JeffR116's Avatar
JeffR116
Try lining up the heatshield and use some sort of silver marker/paint to mark on the black airflow piece. Use an icepick or something similar and poke holes through it. Then just use a screwdriver to get the screws in there.
Are you talking about the two screws in line with each other where the heat shield attaches to the body?
Old Jun 17, 2004 | 08:11 AM
wrendon's Avatar
wrendon
Just try a little harder. At least bolt on the upper screw. If you quit installing the bolts you can slide the shield (the part with the holes) inside the plastic air opening without using the screws then secure the lower part to the body. The heat shield will hold in place. Install the filter then decide if you would go to a shop or simply leave it that way.
Old Jun 17, 2004 | 05:25 PM
tiggerpooh's Avatar
tiggerpooh
so do u mean not putting in the 2 little screws??...is in secure enough
Old Jun 17, 2004 | 07:10 PM
wrendon's Avatar
wrendon
Yes, that's what I mean. Just fit the part with the two holes inside the air vent instead of the outside. The shield would be secure. Try it. It would take you one minute and you will have the feeling.
Old Jun 17, 2004 | 07:21 PM
alphared's Avatar
alphared
Anyone try using Heavy Duty double side tape instead of the 2 screws? Faster and easier.
Old Jun 17, 2004 | 07:29 PM
groovytang's Avatar
groovytang
do you need to screw in the top of the heat shield with the 2 screws? i didn't, does it really matter??
Old Jun 18, 2004 | 12:04 AM
nitrousoxidex's Avatar
nitrousoxidex
What I did was this, I screwed those two bolts that connect heat shield to the car which is at the bottom of the heat shield. At first, I couldnt install those screws on the intake snorkel so I juss did the bottom bolts and it was already tight enough so I left it alone. So far everythings great. After the heat shield, theres nothin really tricky about installing this.
Old Jun 19, 2004 | 02:19 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
you do not need to install those 2 little screws.... 90% of self installed pop chargers do not put those thingies on... atleast of the DIYers that drive into our shop.. hehe
B Esquire
Sep 24, 2015 07:52 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
