.......AND fUJITSUBO headers....[?]
Old Jul 2, 2004 | 09:27 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
yes those are the DC SPort Stainless Steel headers...
I took the pic my self... have them in stock as well as ceramic coated...
the ceramic coated look like this...
Old Jul 2, 2004 | 09:46 PM
islandsnow's Avatar
islandsnow
Default BRM headers?
Those DC's are good looking headers, but has anyone tried these BRM headers, they aren't too badly priced either. Are these the same as the nismos?
Old Jul 2, 2004 | 09:52 PM
Jason@Performance
Performance Nissan
they look simalar to the Nismo's but those are not nismo headers...
nismo headers look a little beefier...
ill take a better pic of the nismo's tommorow.. been needin to do that for a while...
here are the stillen though...
Old Jul 2, 2004 | 09:53 PM
Jason@Performance
Performance Nissan
Default Re: BRM headers?
those dont look like they have the bend to avoid the steering column though...
not good... you dont want to hit the steering column...
Old Jul 3, 2004 | 04:14 AM
islandsnow's Avatar
islandsnow
Now that you mention it, the left and right side do look identical on the BRM's.
Old Jul 3, 2004 | 10:05 AM
MY350Z.COM's Avatar
Nothing can compare to the "Medusa" headers
http://www.crawfordzcar.com
More TQ, More HP than any available header for the Nissan 350Z
Old Jul 3, 2004 | 01:36 PM
garaget's Avatar
garaget
Originally posted by Jason@Performance
the ones pictured above are RHD headers as well...
LHD headers...
its the DC Sport ones but you see the bend is on the left side header
It's weird how you said these are RHD, but when I call them they said that it was designed for LHD only. The dyno sheet is also on a stock engine with cat and stock exhaust.
Old Jul 3, 2004 | 02:19 PM
Jason@Performance
Performance Nissan
I was refering to the Fujitsubo headers...
The BRM are different... the left header has a shorter collector than the right (passanger side)...
you dont see the angle difference in the picture...
Old Jul 3, 2004 | 03:18 PM
esemes's Avatar
esemes
man, im still in the dark about these things, even after MANY positive contributions, pics, and posts.....
will someone JUST PICK a set for me??lol
-eS
Old Jul 3, 2004 | 03:40 PM
Jason@Performance
Performance Nissan
NISMO best for your money if you are going all NA w/ Cams etc...
Crawford too but the install is harder...
Stillen are good too you get alot for the money...
DC Sports if you are staying NA and not doing cams... (Pipe diamater not as large but very good if running test pipes too)
BORLA ehhh... not my fav header for this car....
Old Jul 3, 2004 | 03:43 PM
Jason@Performance
Performance Nissan
nismo headers (new version with the bigger bend for clearance of the steering column.)
Jason@Performance
Performance Nissan
drivers side header...
Old Jul 3, 2004 | 03:45 PM
Jason@Performance
Performance Nissan
if you are running the vortech blower I would use the NISMO... they have the largest diamater and longest collector...
IMHO...
Old Jul 4, 2004 | 05:04 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
DC will work very well with cams....the smaller pipe diameter really has no affect at the type of power levels we are talking here (circa 300 with all the appropriate mods). The smaller pipe diameter simply keeps the power increases in the mid range, where as the units with larger diameter tend to be peakier in the rpm range.
Old Jul 4, 2004 | 03:01 PM
PhoenixINX's Avatar
PhoenixINX
Let me point out that Mike Edens (mjedens), with running the 268s cams found that even the "sworn by" NISMOs were severely restricting the engines breathing...
How much you might ask???
How about 30-40 ft-lbs of torque down low... That's a huge difference!!!
Old Jul 4, 2004 | 03:05 PM
esemes's Avatar
esemes
for the sake of this post, i am setup with a H.O. vortech kit, with crawford headers, fuji catback, and crawford plenum.....
if it matters...........
Old Jul 4, 2004 | 06:54 PM
Z1 Performance
Former Sponsor
from the numbers I have seen, the Crawford seems to provide the goods over a wide array of setups. Are the ones pictured above their usual header? if so, whats the rationale or advantags to using seperate flanges rather than a continuous one...I can think of a few, but not sure if that was their reasoning
Adam
Old Jul 5, 2004 | 01:52 PM
  #38
booger's Avatar
booger
I have the BRM headers. The collectors looked both the same to me...didnt notice any thing diff. about them .I didnt like that the welds inside of the header on both the intake and collector sides were not ground off .I ground them off my self instead of going thru the hassle of sending them back . They fit real well
Old Jul 5, 2004 | 02:45 PM
  #39
PhoenixINX's Avatar
PhoenixINX
Adam
Better fitment.
It'd be less expensive to do one straight flange all the way across, but quality was priority with these.
Old Jul 5, 2004 | 03:41 PM
  #40
Z1 Performance
Former Sponsor
Phoenix - I figured it was to gaur against warpage that can come with making nice tight welds around such a large flange......with the smaller ones this is much less of a concern I am sure.
Thanks for the info......from my customers that have them, all are very happy indeed. If my engine builder likes the overall design, in light of the head buildup we are currently doing, then I may vey well end up with these
adam
