Pop Charger More Inflow
Old Jul 18, 2004 | 12:09 PM
hvrod's Avatar
hvrod
Arrow Pop Charger More Inflow
While reviewing the instructions and installing the Pop Charger. I see in the installing instructions I found online/on this forum... that the bottom wheel well area.. they still have a plastic sound baffle left in as shown in the instructions photos...
Well I removed this... cause I wanted no restriction of air to the Pop Charger... I also saw there was a hole in the aero panel -- that was it to provide air from below.. no read force cooling air could really get it flowing underneath the car..
So, I removed my front bumper/grille, and cut out an additional hole as seen { photo attached... } this allows air being force while driving in that wheel well chamber thats isolated to recieve some cool air..
Then in turn some cool air should be available for th Pop charger to ingest...
Old Jul 18, 2004 | 05:28 PM
MrGoingdown305's Avatar
MrGoingdown305
...So you basically cut a whole in your bumper? Can you give us a picture showing the whole front of your Z?
Old Jul 18, 2004 | 08:05 PM
hvrod's Avatar
hvrod
I would call my bumper the outer part with the paint, grilles..
the inner part I would call the moulding/structure..
thats the part I cut....out..
the whole front end.. I will have to do after work tomorrow..
Will be late afternoon for that... if you really need it..
As you can see the grill , then the back piece cut... thats the part thats cut.. (in the image as, in the first thread..)
Do you really need that pic or can't you tell from the image from the first post?
I can now.. post the actual cut out for you ..
Old Jul 19, 2004 | 01:46 AM
MrGoingdown305
I get it now, thanks for the info and the pics.
Old Jul 19, 2004 | 06:29 AM
03Brickyard's Avatar
03Brickyard
What?
Old Jul 20, 2004 | 04:51 AM
Z BOY's Avatar
Z BOY
I simply removed those two black, plastic panels on either side of the inner part of the grill, opening up the full width of the grill to airflow and protecting the radiator with a mesh grill cover. Are you referring to a different area?
Old Jul 20, 2004 | 05:48 AM
hvrod's Avatar
hvrod
Sounds like the same.. the panel runs parallel with the radiator on the side of it...
07ZEKE
Aug 23, 2021 09:15 PM
kyin
Oct 15, 2015 05:54 AM
B Esquire
Sep 24, 2015 07:52 AM
