Injen SES 1985c Rattle
Old Aug 20, 2004 | 08:07 PM
thunder0880's Avatar
thunder0880
Default Injen SES 1985c Rattle
I got the exhaust the day it came out. So far I have put about 3k miles and I am getting a rattle now. Its only at idle and below 2k rpms. Plus its rattles if I go over a bump. I did a search and couldnt find anything on this exhaust, but did find rattling on the injen angle tip exhaust. Anyone else having this problem?
Old Aug 20, 2004 | 09:19 PM
ares's Avatar
ares
Veteran
look under your car, Id bet youll find atleast one of the pipes is touching the cross member below the exhaust. when I installed mine I actually rested it on there for simplicity. unfortunatly it then tightened into that position and rattled at low RPMs.
I had to jack the car back up. loosen the connection between the exhaust and cats, and stick a peice of wood or whatever in to lift the pipe, retighten and it stays there. no rattle since.
if it doesnt appear to be even remotely close to the cross member or that doesnt fix it; apparently the straight tip version might make contact with some sort of plastic cover for some AC thing in the rear by the passenger side muffler.
Old Aug 20, 2004 | 09:42 PM
jlimquest's Avatar
jlimquest
Default injen true dual exhaust (pics for rattle fix)
Try this link for the fix:
https://my350z.com/forum/showthr...&threadid=84434
PS: GTR emblem on back has been removed.....got a lot of "heat" on it.
Old Aug 20, 2004 | 09:45 PM
thunder0880
link doesnt work
Old Aug 21, 2004 | 03:09 AM
jlimquest's Avatar
jlimquest
Sorry....try this:
https://my350z.com/forum/showthread....threadid=84434
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
350Z Project X
Oct 17, 2015 05:16 PM
Ryan Bonner
350Z Roadster
Sep 8, 2015 04:16 AM
