Rear View mirror Woes
Old Nov 4, 2002 | 12:37 PM
Subw00er's Avatar
Subw00er
Default Rear View mirror Woes
Does anyone else's mirror fall down when the bass is hitting HARD? I love to crank my stereo, but the freaking thing works its way down after big bass.
This isnt really a warranty issue, has anyone found a fix?
ps- I'm only running a 10w6v2
Old Nov 4, 2002 | 01:06 PM
ares's Avatar
ares
Veteran
uhhh no not a problem but then again I have a stock sound system. they wont fix this underwarrenty since its caused by an aftermarket component. sounds like its just not stiff enough fit to hold up, I donno how you could make it stiffer...
Old Nov 4, 2002 | 04:41 PM
abz123's Avatar
abz123
Is there a screw or something you can tighten?
Old Nov 4, 2002 | 05:02 PM
ares's Avatar
ares
Veteran
Id suggest finding someone with a service manual that can take a look on how its put togehter,if its like a ball socket thing, perhaps you could coat it with paint or slip a peice of paper in there to tightin up the joint, but that will probably loosen up again in time.
Old Nov 5, 2002 | 04:48 AM
Subw00er's Avatar
Subw00er
There is no screw and it is a ball-socket type. I dont see how I could get paper in there. its a pretty tight tolerance.
Old Nov 5, 2002 | 05:43 AM
Mike821's Avatar
Mike821
super glue?
j/k
Old Nov 12, 2002 | 09:20 AM
roark's Avatar
roark
I'd suggest a very careful application of BLUE locktite to the ball. Swirl it around a bit to get some locktite into the socket. The blue locktite will gum up in the gap and should do the trick without freezing the whole assembly like a glue would do.
If possible, I'd recommend removing the mirror and stalk when you do this, otherwise some locktite will drip.
Old Nov 12, 2002 | 10:53 AM
Zoro's Avatar
Zoro
Default come on ?
Originally posted by Mike821
super glue?
j/k
Don't be ridiculous, since it needs to be adjustable for other drivers, duct tape is the only way to go.
Old Nov 12, 2002 | 01:16 PM
importriders's Avatar
importriders
If it is a painted surface, I would suggest againts locktite. Locktite eats paint. But if you don't car about the paint on the mirror or its not painted at all go for it.
