Brake light comes on when pressing brake also vdc and slip on light too???
Old Feb 9, 2005 | 04:59 PM
OptimusP517's Avatar
OptimusP517
Default Brake light comes on when pressing brake also vdc and slip on light too???
Now I'm guessing i'll need new brake pads and probably rotors are cause they're warped. But how in the world does my vcd and "slip" light get triggered too. Once in a rare while it'll be triggered and stays on until i turn the car off. Now when I step on the brakes hard the "brake" light comes on.
One last question, can you turn the rotors on the nissan or do you have to buy new ones?
Also how do you read the wear indicator on those damn pads? I don't undertsand it too much, but of course I haven't taken my wheel off yet and checked it out myself
Old Feb 9, 2005 | 06:09 PM
westpak's Avatar
westpak
SFZCC
The brake light is probably due to low brake fluid due to wear on the pads causing more fluid to go into the lines, just ad some fluid.
The pad wear is hard to see depending on what model you have but if you look at an angle you can see the edge of the pad (non-brembo) But they will have a wear indicator which starts to chirp when you hit the brakes indicating the pad is worn down.
As for the slip light not sure why that is coming on unless you have changed wheels/tires and didn't keep the original overall dimensions.
Old Feb 9, 2005 | 06:52 PM
OptimusP517
i'll go pick up some brake fluid from nissan and just throw it in there then, what else should i look for, last time i checked my brake fluids didn't look low at all
Old Feb 9, 2005 | 07:12 PM
westpak's Avatar
westpak
SFZCC
Old Feb 9, 2005 | 07:13 PM
westpak's Avatar
westpak
SFZCC
The fluid might be fine when at a standstill but when you brake hard the fluid goes into the system to apply the brakes, plus the movement of the fluid in the reservoir, and probably goes down just enough to set off the light.
Old Feb 9, 2005 | 07:53 PM
OptimusP517
i see, yeah i'll just go to a stealership and pick up some fluid unless you recommend me something else
Old Feb 10, 2005 | 05:09 AM
grifferjr's Avatar
grifferjr
yeah its definately the brake fluid. putting some in will buy some time. but it is a sure indicator that your pads are wearing, so you will need new pads probably in the next 2-3 months, depending on your driving style. so you might want to get that done also. at least doing it now will prevent any chance of doing any abnormal rotor wear.
Old Feb 10, 2005 | 08:00 AM
OptimusP517
well I know for a fact that my rotors are warped. I've ran my fingers through them and I can feel that curve. Now I'm assuming you can't turn the rotors on the 350z right?
Old Feb 10, 2005 | 10:21 AM
westpak's Avatar
westpak
SFZCC
Thay can be turned.
Old Feb 15, 2005 | 06:21 PM
Blympie's Avatar
Blympie
As a technician in training I command you to go get your brakes worked on. The thing is is the longer you wait the more expensive your brakes get. If your pads are low or you are losing brake fluid you might have another problem than pads if they arent low. Brakes save your life. GO GET THEM FIXED ASAP. b4 you have to replace the caliper's!!!
Old Feb 15, 2005 | 09:34 PM
OptimusP517
thanks for the advice from a tech yeah I know by experience if you wait longer you'll just end up paying an arm and a leg for it. I work with a bunch of techs at my stores and I'm having someone work on them for me. I'm not sure if I want to turn them still or get some cryogenically treated rotors.
Old Feb 18, 2005 | 06:13 PM
CopperZ's Avatar
CopperZ
I had the same thing happen to me, vdc, and brake light came on, went to the dealer and they said the abs sensor is bad. no brake fluid needed.
Old Feb 18, 2005 | 08:26 PM
OptimusP517
weird, the lights are now gone, hmmmmm wonder whatsup, i should probably take it to the dealership and have it warrantied before i sell it then Did they warranty it copperZ?
Old Feb 18, 2005 | 10:50 PM
CopperZ's Avatar
CopperZ
Oh yea it was all warranty.
Old Feb 18, 2005 | 10:54 PM
OptimusP517
nice i'll be going in then, well i got extended warranty anwyays that should cover it too!
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
