Chrome Rear Turn Signals Problem PLZ HELP
Old Feb 28, 2005 | 03:05 PM
LaidbackRacr's Avatar
LaidbackRacr
Default Chrome Rear Turn Signals Problem PLZ HELP
I installed chrome turn signals in the rear of my car yesterday after I had already done the Front and worked just fine. Now the rear blinks really fast meaning that the rear is not completing the circuit. Now granted these were a PIA to install I do not see the problem has anyone else approached this issue or knows how to correct it.
Thank,
Chris
Old Feb 28, 2005 | 05:46 PM
myz8a4re's Avatar
myz8a4re
if they blink fast they are not installed correctly chris. for example, if you pull one of the bulbs out & turn the signal on the light will blink rapidly telling you that a bulb is burnt out or somthing of that nature. double check to be sure the bulb is seated in the harness correctly. before reinstalling the tailight check the bulb flash by turning on your signals. try your stock bulbs in the same locations & check the flash speed with them. it may be the new bulbs. are they lighting up in the rear? sorry i cant be of more help........
-justin
hulkout
Apr 28, 2017 09:00 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
TDPrank
Sep 29, 2015 12:51 PM
TDPrank
Sep 28, 2015 06:29 AM
samansharif
Sep 25, 2015 12:31 PM
