oil level problem
Old May 27, 2005 | 02:47 PM
GWAPITO69's Avatar
GWAPITO69
Default oil level problem
need to know what causes this? i checked my oil level and it's almost on the lowest level. I had it oil changed last march, checked it and everything was good. I don't see any leaks underneath the car. Just need to know what's wrong with my engine
Old May 27, 2005 | 02:59 PM
zand02max's Avatar
zand02max
last march, as in 04?
Old May 27, 2005 | 03:18 PM
GWAPITO69's Avatar
GWAPITO69
march 05 2005 (couple of months ago)
Old May 27, 2005 | 03:23 PM
zand02max's Avatar
zand02max
get it checked by the dealer.
Old May 27, 2005 | 05:01 PM
n8vz's Avatar
n8vz
how many miles do you have? burning oil?
Old May 27, 2005 | 06:56 PM
GWAPITO69's Avatar
GWAPITO69
I'ved got 26000 miles. yeah it seams like it's burrning coz sometimes i can smell it from inside the car which i thought that it was coming from the car infront of me.
Old May 27, 2005 | 09:37 PM
Z BOY's Avatar
Z BOY
get an "oil consumption" test done by the dealer.
Old May 30, 2005 | 06:25 AM
bwilliams's Avatar
bwilliams
What's wrong with your engine is a wide open question. First, determine if there is, or is not something wrong...do the oil consumption test yourself:
How many miles since your March 5, 2005 oil change?
How much oil to top it off?
This is your consumption... x quarts / xxxx miles
I don't know what Nissan says is normal (probably anything that makes you go away), but the service interval to change the oil is 3750 miles. The range capacity on the dipstick is about a quart. That's one quart per 3750 miles. If it's normal for the engine to have a higher consumption rate, they would have a "check oil" interval at say...2k miles. Use that as you wish when talking to Nissan.
Mine uses half quart per 4k miles, but I still check it about every 1k.
Old May 30, 2005 | 06:29 AM
Z BOY's Avatar
Z BOY
>1qt/1k mi is abnormal, per nissan.
Old May 30, 2005 | 07:58 AM
bwilliams's Avatar
bwilliams
zboy, is that in the svc manual or did your dealer give that figure to you. Seems like a lot. Maybe 1qt/1k is when the engine needs internal work?
Old May 30, 2005 | 09:05 AM
Z BOY's Avatar
Z BOY
service manual
Old Jun 6, 2005 | 09:43 AM
Th3Cleaner's Avatar
Th3Cleaner
I have had mine in the dealership 2x now for no oil in the engine, oil light on all the time
I had the oil consumption test done, and they said it was not burning any oil, but yet every 3K miles it seems to have no oil in it.
Pipes are always black, I never smell oil.
I don't know just a screwed up weak engine i guess.
Uriyo_
Sep 8, 2021 08:46 AM
