Cruise control
Old Jun 13, 2005 | 12:36 PM
anotheraznguy's Avatar
anotheraznguy
Default Cruise control
ok i've had the car for about 2-3 months now.. and on saturday was the first time i tried using my cruise control.
ok so anyhow.. i press the on button and then press set and theoretically the cruise control is supposed to work.
SADLY IT ISNT WORKING
so now i have to take it back to the dealer..
but before hand i will return the car to stock and prevent them from yelling or scapegoating some of my mods for the cause of it.
Old Jun 13, 2005 | 10:46 PM
The Liu Man's Avatar
The Liu Man
keep trying to use it and read the manual... it took me awhile to figure out how to make it cruise. also try holding the set button for about 1 second. it's finicky.
Old Jun 14, 2005 | 06:33 AM
Qbrozen's Avatar
Qbrozen
+1
You really have to flip the Set switch fully and deliberately. And I'm assuming you can see the "cruise on" light when you hit the On/Off button before trying to hit the set switch (which will bring on a second light indicating its "set").
Old Jun 14, 2005 | 08:46 AM
anotheraznguy
ok... so
i push the cruise switch to turn it on.
and the green cruise light comes on..
and then
i must push the set switch and hold it for about 1 second? and then another set light will come on?
Old Jun 14, 2005 | 09:10 AM
FindingNismo's Avatar
FindingNismo
Yes. You should have 2 lights on while in cruise. The middle button on your steering wheel turns it on (notice light turns on near your gas gauge) then flip the top toggle switch above the "on/off" button DOWN to "set" your cruise (2nd light turns on right next to the on light). My 04' doesn't give me ANY problems with cruise. No waiting a few seconds, no flipping it a bunch of times or whatever. Perfect! OH... Maybe you're going to slow? I had a Mercedes that wouldn't let me cruise unless i was in 6th gear and doing more than 45mph. Just a thought?
Old Jun 15, 2005 | 08:55 AM
anotheraznguy
ok i tried it today... went 75 mph and tried holding it down.. my cruise control still is not working... any ideas?
i guess i have to take it to get the warranty work done.
Old Jun 15, 2005 | 11:30 AM
FindingNismo
Ok.. stupid question. You're leaving it in gear and still holding the gas pedal down while trying to put it in cruise correct? And still nothing? Yup.. i'd say it's broke. With there only being one button and one switch to put your Z in cruise, i'd say it's busted.
Old Jun 15, 2005 | 01:21 PM
Fuddy Duddy's Avatar
Fuddy Duddy
Check your fuses. That could be the problem.
Old Jun 15, 2005 | 02:31 PM
anotheraznguy
i checked all the fuses... and nothing is blown.... sigh... this sucks...
Old Feb 12, 2009 | 07:35 PM
kaizenro1's Avatar
kaizenro1
BUUUUUMP!
My cruise worked on the test drive but I cannot get it to work.
Old Feb 12, 2009 | 10:41 PM
J350z101's Avatar
J350z101
Press Cruise, then flick the bar/tab downward to set the cruise... after it is set you can adjust the speed by pushing the tab up/down...
sales@czp
Sep 23, 2019 03:30 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
