miss shift... might have done damage....
Old Aug 10, 2005 | 08:24 PM
Bran_BranZ33's Avatar
Bran_BranZ33
Default miss shift... might have done damage....
so the story goes im leaving the movie theater and this mustang wants to play. Well anyways im getting on to the highway and i shift from third to second(put on flame suit) pretty hard. i didnt get to see how high i went but i know it was past 8k. well now my speedometer is off for some reason. im going about 70 and it says 90 and when im stopped it says 20 and then slowly falls to 0. i dont know whats up but i pulled over and shut the car off for a minute and it is still off. whats the deal. i guess my question is if i take it to the dealership will the computer tell them that i miss shift? My buddies RSX threw a rod this way under warranty and the dealership told him tough luck, this falls under abuse and we dont have to cover that.
brandon( has never done anything like this before and only has 10k on his Z)
Old Aug 10, 2005 | 10:33 PM
DRFT86's Avatar
DRFT86
Did your engine light go on??? if so then it definetly recorded the 8000+ rpm and i doubt the dealer would replace anything becuase they will know it was driver error... if the CEL didnt go on then you might have a chance that it didnt log that RPM but im not 100% sure.... get more opinions first..
Old Aug 11, 2005 | 05:03 AM
Bran_BranZ33
The light didnt come on and hasn't. but our ECU's do record rpm spikes? **** i hope nothing is messed up. do you think if i disconnect the battery and reset the computer it will fix the speedo.
Old Aug 11, 2005 | 06:07 AM
Bran_BranZ33
anyone have any ideas?
Old Aug 11, 2005 | 06:12 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
worth a try, itll also reset your clock ( i still cant figure out how to change the mintues on my bose stereo, its off by 15!!!! )
Old Aug 11, 2005 | 06:15 AM
Bran_BranZ33
lol!.. thats the least of my worries right now.
Old Aug 11, 2005 | 10:18 AM
the7ferret's Avatar
the7ferret
spedo error and miss shft are different things,
If you damaged something in the engine / tranny you would have bigger issues.
The spedo issuse could be considered a safety issue and they should adress it immediatly. If they give you any hassel about you misshifting tell them "so isnt that a different part?"
Old Aug 11, 2005 | 10:41 AM
Bran_BranZ33
yeah its still messed up and i have no idea why miss shifting would cause the speedo to malfunction. its weird. the dealership was my last resort but i guess i have no other choice.
Silkk's Avatar
Silkk
My tranny is particular picky about going from 3rd-4th hard and I've shift from 3rd-2nd a few times and caused a high RPM spike... I've never seen the RPMs shoot to 8000 as it is limited, but I've bounced it off the limiter several times hard and I have no issues thank god... Usually I'm pretty quick about getting the clutch depressed again and getting it into 4th, but the spike still isn't cool.
My speedo has never gone crazy from it though. I wouldn't worry about it unless you hear rod knock or some other crazy engine noise.
Like I said, this happened to me at least 3 times and and no issues.
Old Aug 11, 2005 | 11:05 AM
Bran_BranZ33
yeah the car runs fine from what i can tell, no noises. You know ive bounced of the rev limiter a few times come to think of it, but this time it went right through it. strange. i wonder why that is.
Can someone tell how the digital speedo is connected to the regular one? they are both reading the same wrong speed. does the ECU control them both?
Old Aug 14, 2005 | 09:28 PM
Tackett's Avatar
Tackett
Its funny you say that, because I did the same exact thing twice in a row yesterday and about made my heart stop. I havent started my car up at all today for fear of something totally wrong with it. Makes me feel good that Im not the only one that did that.
Old Aug 14, 2005 | 09:41 PM
SizongZ's Avatar
SizongZ
have you tried reseting your ecu?
Old Aug 23, 2005 | 11:21 AM
shortbus1981's Avatar
shortbus1981
You guys do know you can set the rev limiter lower so as not to spike it.
Old Aug 30, 2005 | 07:22 PM
done12many2's Avatar
done12many2
In the case of mis shifting, the rev limiter will not keep your motor from going over a preset RPM. If you accidently downshift when intending to up shift, the speed of your vehicle is going to determine how high your engine over revs. Not the rev limiter.
Old Aug 31, 2005 | 05:22 PM
350zWarz's Avatar
350zWarz
if you're talking about on the first digital gauge in the center, that is only a setting where it tells the shift light start to come on, it can't raise or lower the rev limiter
Old Aug 31, 2005 | 05:40 PM
Kolia's Avatar
Kolia
Just get her to the dealer and play dumb.
Never ever talk about that incident. It never happened...
Old Sep 1, 2005 | 07:03 AM
Bran_BranZ33
well the story goes like this. I took my car in and told them my problems and just played dumb about the hole thing. just said fix it. well they said they didnt know what caused the speedo problem and they fixed it. i also got an early oil change just to be safe. thanks for all the help.
Old Sep 1, 2005 | 08:35 AM
Agreed. Usually the most simple answer is the best.
Jambo016
Sep 16, 2016 01:08 PM
chief3630
Feb 29, 2016 02:54 PM
TrboMike
North East
Sep 28, 2015 06:36 PM
pslamp32
Sep 14, 2015 03:05 PM
