Another window problem....
Old Aug 23, 2005 | 02:09 PM
iheartZ's Avatar
iheartZ
Default Another window problem....
hey guys i was just wondering if any of you guys have had a problem with your driverside window rolling halfway back down after you roll it up all the way on auto rollup... my car seems to have this problem lately... i will roll the windows back up on auto and it will roll back down about a quarter...please help a brother out!
Old Aug 23, 2005 | 02:12 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
your window regulator / motor is going out... either needs to be reset or replaced...
Old Aug 23, 2005 | 02:43 PM
BluZee's Avatar
BluZee
I would try having the limit switch reset. That has been the fix for every 350Z that Ive seen with that problem.
Old Aug 23, 2005 | 03:53 PM
RNL323's Avatar
RNL323
Mod My Ride
Happened to me recently. I was still within waranty so dealer replaced motor at no cost. I recommed taking care of this soon... I waited too long and my window locked on me. It wouldn't roll down at all!
Old Aug 23, 2005 | 04:50 PM
taurran's Avatar
taurran
Damn this is happening to me too. It works most of the time. This will be the 6th time I've taken the window in to get fixed for bad motor/track/grease marks.
Old Aug 23, 2005 | 05:10 PM
Greenvette95's Avatar
Greenvette95
My 03 is doing the same thing. It goes to the dealer Saturday.
Old Aug 23, 2005 | 08:54 PM
iheartZ's Avatar
iheartZ
wut?! its only got 4k miles on it and ive already had that motor replaced... hmmmmmmm
Old Aug 24, 2005 | 09:00 PM
jinsei888's Avatar
jinsei888
can the reset be done myself without going to the dealer? I have the TSB and service manual OEM on PDF showing me the procedure and I have sufficient experience working on many automobile mechanics and electronics. I'm just unsure about the part about the Fitting Inspection. I am under the assumption that process is only necessary if the motor regulator or glass was removed. If I simply am reseting the regulator, the parallel alignment of window to the sash should remain the same, correct?
Siqcology
Sep 18, 2019 01:45 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
AP350z223
Sep 8, 2015 04:38 PM
