pedal shaking at 1800 RPM
Old Sep 29, 2005 | 07:35 AM
jukljs's Avatar
jukljs
Default pedal shaking at 1800 RPM
Has anyone experienced this:
I have an 05 350z, 6000 kms. When driving in first gear, when I get to 1800 RPM, it sounds like my car starts to grind and my gas pedal shakes pretty bad, about a second later, it will go back to normal.
From what I have read on this forum, when people talk about griding, it happens while changing gears but I am already in gear when this happens so i dont think it is the same problem as that.
Thanks
Old Sep 29, 2005 | 09:10 PM
Miko's Avatar
Miko
Just curious, was your car built in Opamma or Tochigi?
It'll say on the vin before the last 6 digit number, it'll be either M or T; M=Tochigi, T=Opamma
Just wanna see if this is a problem w/ Opamma plant or both..since i've heard good things about the Tochigi plant.
Old Sep 30, 2005 | 07:28 AM
jukljs's Avatar
jukljs
It's M
Old Oct 5, 2005 | 08:55 AM
jukljs's Avatar
jukljs
i took it in and they said all the new cars with abs make this noise and its the its the abs turning on and testing itself.
Does anyone else's car do this?
Old Oct 5, 2005 | 10:33 AM
HarvesterUT's Avatar
HarvesterUT
i have an 05 6speed and never had my gas pedal shake.......dunno
Old Oct 5, 2005 | 12:20 PM
mavtais's Avatar
mavtais
Shop is full of BS, jukljs!!!
Do you have an aftermarket flywheel? Aftermarket flywheels make the tranny loud.
ABS has been known to test itself occasionally right before taking off after startup, but not while you're in gear. Take it to another shop.
Old Oct 5, 2005 | 12:31 PM
jukljs's Avatar
jukljs
the only thing i have is a jwt popcharger.
Thanks for the reply's, im going to take it to another shop.
Justin100
Nov 29, 2015 03:58 PM
