getting rid of rust?
Old Oct 3, 2005 | 01:00 PM
HarvesterUT's Avatar
HarvesterUT
Default getting rid of rust?
i recently purchased a set of oem cats and i plan on gutting them myself. the flanges on the ends have rust on them and i was wondering if that would cause any problems with the gaskets when bolted on. is there a way to get rid of the rust, or at least on the side that will secure to the gasket?
any ideas appreciated
Old Oct 3, 2005 | 04:48 PM
yeperra's Avatar
yeperra
Take them somewhere to have it bead blasted. Usually they use glass beads. Sand works too but the finish is not as good.
Old Oct 3, 2005 | 07:56 PM
Once oxidation starts, its next to impossible to stop. Try rust removing jell. Apply with a brush, let sit, rinse with hose. Pretty easy to use.
Old Oct 4, 2005 | 04:05 PM
bmxox's Avatar
bmxox
If the rust is terrible to the point that you can pick off pieces of metal then yes you will most likely have a problem in the near future. But if its just minor surface rust you wont have any problems, its going to rust anyway once you put it on there.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
samansharif
Sep 25, 2015 12:31 PM
z33z_nutz
Sep 23, 2015 07:22 PM
