A/C problem
Old Oct 15, 2005 | 02:26 PM
MeetJoeAsian's Avatar
MeetJoeAsian
Default A/C problem
anyone have/had problems with their A/C? Recently, very often when I have my fan speed on AUTO, it would blow at full strength, and all of a sudden, just stop...then a few seconds later, start again, and off again after a few....I think it's only my automatic climate control system, cuz whenever I switch it to a speed, it would blow constantly...and the other day, I noticed that it actually blew out HEAT...yes HEAT, it was cool, and then it stopped, and then blew out HEAT very softly, then stopped after a few seconds....help?
Old Oct 15, 2005 | 03:05 PM
gabez33's Avatar
gabez33
are you still under warranty??? Sounds like the white ac amp box is starting to foul out...btw the part is on national back order cause of recent problems
Old Oct 15, 2005 | 03:43 PM
MeetJoeAsian
yah...i'm still under warranty so I'm not worrying about it...what's the problem that's putting the part on backorder?
Old Oct 15, 2005 | 03:48 PM
baileyrx's Avatar
baileyrx
actually thats how its programmed to work. Unfortunatly it's very jumpy. It willl blow to get it to the set temp, then stop, because its there. Opps, to cold, turn the hear on for 5-6 seconds... opps to hot.. hit a/c hard.. etc.
i use the manual mode to avoid all this. my wifes expedition does this also.
Think of "cruise control" for the HVAC system.
Old Oct 15, 2005 | 04:06 PM
bmxox's Avatar
bmxox
Sometimes when I start my car the ac will just come on full blast even though the **** is definitily turned to off. I have to switch it on and then back off to get it off, it has happened 3 times in the past month.
Old Oct 15, 2005 | 10:56 PM
MeetJoeAsian
I know how automatic climate control system works...my last 3 cars have had it, so i know how it works....this is how it works, if you have it on the lowest or highest possible, it will always blow at full blast, if you select anything between the 2 extremes, your a/c will slow down once it's reached the desired temperature inside...my problem is that when it's on full blast cold, it cuts off as if i turned off the a/c and then on again....a few times, it activated the heat....none of my previous car had this problem...they all worked in similar fashion...and my m3 doesn't have this problem either right now...
Old Oct 16, 2005 | 07:55 AM
gabez33's Avatar
gabez33
Many Z drivers' AC system been messing up and 90% of time it was traced back to the white ac amp box blowing a tiny transistor...I got mine replaced already once everything works cool now I had to drive around in texas heat for 3 weeks with no ac while hte part came in
Old Oct 16, 2005 | 07:19 PM
meme's Avatar
meme
i have 04 enthus. sometimes while just started the car or driving the A/C will turn on automaticlly. i would have to hit the A/C button to turn it off.
i have the A/C button off and the fan **** @ off. and temp all the way counter clockwise.
is this normal? this is my first car that is actually pretty new and has A/C
Old Oct 16, 2005 | 07:36 PM
gabez33's Avatar
gabez33
No thats not normal, nothing should turn on and off unless you tell it to.... I would take it to the dealership.
Old Oct 16, 2005 | 08:09 PM
sbcbaseball's Avatar
sbcbaseball
Ditto i thought i was crazy when my ac turned on while the **** said off. it started doing this a couple months ago and now it seems to be doing it every other day. I talked to a nissan engineer and he said i have to duplicate the problem and im like WTF. Good to hear im not only one with this problem.
Old Nov 1, 2005 | 04:23 PM
backagain's Avatar
backagain
any idea how much that part is ? i think i might have blown mine somehow. anyone have a part number ?
Old Nov 1, 2005 | 08:28 PM
gabez33's Avatar
gabez33
I think the part goes for around $400, not 100% sure though...let me see if I can find out///
Old Nov 4, 2005 | 08:45 AM
gabez33's Avatar
gabez33
sorry late response---its $585 and about a 2-3 week wait on it.
Old Nov 10, 2005 | 11:58 AM
bmxox's Avatar
bmxox
Thats exactly what I thought they would say so I didnt even try to talk to anyone about it. Its so random they would need to drive my car for like a week to get it to do it.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
