Service Engine Soon after Radio Install?!
After installing my Kendwood DDX , the "Service Engine Soon" light came up?
f**ing cables are so damn hard to get in there with out brutal pushing , hope I didn't kill a cable, but I checked it again an nothin is cut off or somethin ??
I did fill up the car, but the light didnt go on right after fillin it up?! later that night I installed my radio and after starting up the car the "SES light" when on?
I check my gas cap again and turned it a couple of times but the light is still oN?!
Did you unplug the little white box under the radio and behind the AC controls with the battery still hooked up? If so that is it, that box process many signals that will set off the light if diconnected with the battery still hooked up, lesson is to disconnect the battery before doing the work.
Originally Posted by VashZ350
sh*t ! yeah I did disconnect the little white box... take it to the dealer?
Guest
Posts: n/a
could that white box cause the buttons on the radio not to work? and for it to cylce through the audio options by itself?
none of the buttons on my stock bose radio work. only the volume control. and i had the shift console out a few days ago messing with a shift ****. any relation?
the radio works fine I can controll everything...why?
Originally Posted by pargion
i had the same problem after i installed my alpine head unit...some guy advised me to unplug the negative terminal of my battery and leave it for about 12 hours (overnight). came back, plugged it back in, and the light was gone. no problems ever since. voodoo magic, coincidence, or an actualy fix? who knows, but it made the light go away
Originally Posted by westpak
That reset the ECU so same effect as reset procedure.
Thanks
