bad brushings?
Old Dec 23, 2005 | 06:46 AM
gimpster621's Avatar
gimpster621
Default bad brushings?
car handles fine, but on sudden jerks to the left while moving, i hear a loud audible "takk." i thought it was the control arms but im pretty sure its the brushing. if so, how bad is it to drive with a bad brushing for about a week. dont have time to work on the car right now.
Old Dec 25, 2005 | 10:39 AM
gimpster621
Bushings. my bad. well took a look under the car and all the joints and mounts look fine. the sound only happens once in a while. alignment seems fine both with the throttle on and off. should I be concerned or is it not a serious issue?
Old Dec 27, 2005 | 09:59 AM
VO...'s Avatar
VO...
Administrator
I had a popping noise, similar to a ball joint popping out of place. It only happened when I made sharp turns with the steering wheel cut all the way. I was something in the undercarrage. Not sure what it was, but the dealer found it. It took about a week to replicate and find out what the cause was. They used some kind of monitoring device, that you attach to strategical points on the suspension. They then test drove the vehicle while this device measured abnormal vibrations. This is how it was explained to me. Like I said, they found it a week later and repaired it. Good luck.
Old Dec 28, 2005 | 09:11 AM
gimpster621
how much did the charge you
Justin100
Nov 25, 2021 06:26 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
