Instructions on changing oil
Old Jan 12, 2003 | 11:16 AM
mkabrisky's Avatar
mkabrisky
Default Instructions on changing oil
Any member here have instructions on changing oil or tips/tricks to do it properly? I will do it next week and wanted some insight. Thanks. I suspect it is a bit different than my Honda.
Old Jan 12, 2003 | 11:30 AM
Michael-Dallas's Avatar
Michael-Dallas
It's real easy if you have a socket-type filter wrench and ramps made from 2 2x4's stacked/nailed w/ the ends cut at 45*.
1- drive the 350 on the ramps
2- unbolt & remove plastic shield from under the front of the car (~10 10mm bolts & 1 plastic clip)
After that, filter and drain plug access should be real easy if your arms are long enough.
Michael.
Old Jan 12, 2003 | 05:10 PM
ATL350Z's Avatar
ATL350Z
Even with a good filter wrench, you should at least be prepared to have to punch a hole through the filter. The first filter is practically impossible to remove.
Old Jan 12, 2003 | 07:23 PM
MannishBoy's Avatar
MannishBoy
Only do that as a last resort. I once had a filter twist off the shell and leave the "nut" and base part of the filter on the car. That was fun to remove
Old Jan 13, 2003 | 10:10 AM
zPilott's Avatar
zPilott
FYI, for the plastic clip, use a standard screwdriver or similar to pop up the center pin. This wasn't immediatly obvious to me when I was removing the piece. for subsequen oil changes, you can probably replace the filter through the hole, but I seriously doubt you can get the factory one off without taking the shield off.
Old Jan 16, 2003 | 09:19 AM
WayneTN's Avatar
WayneTN
Guess you could always let the dealer do the first one. Maybe the second one would be easier.........
WayneTN
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
