Squeak in rear passenger side(suspension)
Old Jan 19, 2006 | 01:48 PM
Zexy's Avatar
Zexy
Default Squeak in rear passenger side(suspension)
Well i've had my Tein Basics for about 8 months and 12000 miles now. I recently started getting a squeak in my rear suspension when i accelerate/decelerate sort of rough so it happens when there is weight transfer when i stop/go. It does not happen in the driver's side.
The weird thing is it does not make the noise when i go over bumps. It sort of sounds like a bed spring or a classroom seat sqeak if you're not sure what type of squeak i'm listeneing to.
Any ideas guys?
Old Jan 19, 2006 | 02:13 PM
zillinois's Avatar
zillinois
That happened to me too. The noise went away by itself after about 2 months. It only did it at certain times. I know exactly what you are talking about though. I called Performance Nissan even to ask if the shocks were under warranty. But the noise went away shortly after I contacted them. Sorry that doesn't help you one iota, but maybe its a normal.
Old Jan 19, 2006 | 04:17 PM
Zexy's Avatar
Zexy
Let me add im now doubt it's the shock setup or maybe any suspension component.
I've read other threads on axle click and that seems like my issue.
The noise only happens when i'm in gear accelerating or downshifting. I don't hear a peep going over speedbumps so the problem seems like it is obviosly associated with drivetrain and not the suspension.
Old Jan 29, 2006 | 08:29 AM
NA&CH's Avatar
NA&CH
I think my axle(s) are starting to click My gf and I are both hearing click noises when I am in reverse. Does that sound normal? I need to get it checked.
Old Feb 3, 2006 | 07:42 PM
YBLegal's Avatar
YBLegal
it has to do with a barring in your axle. take it to you dealer.
they fixed it with in an hour. its been over 10000.. since, still no sound
Old Feb 3, 2006 | 10:11 PM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
+1 on axle click, all they do is remove axle,clean,regrease,install and turn it 1/2 a turn more. they did both sides of mine just to be safe, only my passenger side was making the noise. it sounds like a couple of washers klinging together.
Old Feb 3, 2006 | 10:16 PM
visionboy's Avatar
visionboy
does this happens on 05 model too? or is this problems from earlier models?
Old Feb 4, 2006 | 08:53 AM
YBLegal's Avatar
YBLegal
mine is 05 model.
350Z_Al
Oct 29, 2020 07:44 PM
samansharif
Sep 25, 2015 12:31 PM
