Drivers side window stuck down.
Old Mar 12, 2006 | 08:46 AM
MyZ4U2C's Avatar
MyZ4U2C
Default Drivers side window stuck down.
I go to wash my car this morning and when i hit the button for the window to go up-nothing. Notta. Just a clicking noise every time i hit the button to go up or down. You can hear a clicking noise like its trying to raise the window but thats it. Any ideas? Thanks in advvance.
Old Mar 12, 2006 | 08:50 AM
jinsei888's Avatar
jinsei888
punch and hit the side of the door from inside the drivers seat around the area just above the window switch finisher (where the window regulator sits) while you are holding up on the switch, and it will work...you know how our Z's are...****ty window regulators and all hah
Old Mar 12, 2006 | 08:56 AM
MyZ4U2C's Avatar
MyZ4U2C
Thanks...i'll give it a shot! I just searched for window problems and ive seen a LOT of threads...i didnt know it was that common of an issue.
Old Mar 12, 2006 | 08:59 AM
jinsei888's Avatar
jinsei888
the thing is, a LOT of people took their Z's to the dealer to get a warranty fix and replacement of the regulator, the thing though, was that the problem would keep coming back even after a new regulator....to be honest, the regulator is flawed from day one, Nissan has never released a new model regulator, so we just keep replacing it with another time-bomb reg thats just gonna keep breaking...sad really...
Old Mar 12, 2006 | 10:02 AM
MyZ4U2C's Avatar
MyZ4U2C
Freakin hilarious!! I did just as you said and went out and hit the door while pressing the button and presto!! Window went right back up. Thanks for the tip.
Who would have thought that i'd have to hit my door to get the window up in a $35,000 car? I still love my Z but man this thing has some quirks sometimes!
Old Mar 12, 2006 | 11:22 PM
cwerdna's Avatar
cwerdna
Not sure what year the OP's Z is, but BOTH of my window regulators and motors failed around the same time. Luckily, I was till under warranty and they got replaced.
Old Mar 13, 2006 | 03:21 AM
PoWeRtRiP's Avatar
PoWeRtRiP
use a pencil or ruler to pry the window out. place the ruler against the window in the door and push it out while pulling on the window switch.
i had this happen too many times on my 350z. usually if you can manipulate the window around in the track while trying to raise the window it will go up.
Old Mar 13, 2006 | 03:27 AM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
Mine got really bad on my G, depending on if I wanted to open or close the window I had to hold the switch either up or down; open, then close the door hard while holding the switch.
Old Mar 13, 2006 | 03:37 AM
PoWeRtRiP's Avatar
PoWeRtRiP
oh and even if they replace the regulator it will likely come back. i had them replace the regulator 2x and it still did it.
Old May 2, 2008 | 11:07 AM
GreekZ33's Avatar
GreekZ33
holy ****! my passenger window just stoppedworking like 20 mins ago. i started reading these threads and was pissed because i thought i would have to at least take the door apart..... and then i read this thread. it really works if you hold the switch up and bangon the door! how ghetto.. but awesome that it didnt cost anything to fix!
Old May 2, 2008 | 11:17 AM
VO...'s Avatar
VO...
Administrator
+1. It does work, but will eventually fail completely. Leave the window in the up position until you fix it...
Old May 2, 2008 | 11:48 AM
ColecatZ's Avatar
ColecatZ
A more civilized approach, well it doesn't feel like abuse to the car, is to hold the window switch up as you close the door. You don't have to slam it, but close it with some assurance. It's the same effect and worked for me several times before my window motors were replaced on my '03.
Old Jun 6, 2008 | 04:34 PM
teeterz's Avatar
teeterz
lol that is so hilarious, same problem for me..semi-slamming the door while holding the window switch UP makes it go up
Old Aug 24, 2020 | 04:43 PM
ed_circus's Avatar
ed_circus
im currently having the same issue
Old Aug 27, 2020 | 07:18 AM
travlee's Avatar
travlee
Master
see this, second post
Old Mar 30, 2021 | 10:05 AM
hank3's Avatar
hank3
O.K. Cool that the Ghetto method works (and it saved my a*s a number of times) I did watch a few good YouTube videos on how to remove the inside door panel to access the motor BUT I also saw one guy that replaced the passenger side window motor and discovered he only needed to replace the window switch in the passenger door. This allowed the passenger window to function and be activated normally on the driver side switch.
Question: How do I determine if my window stuck in the down scenario is the Switch or the Motor ?
Old Mar 30, 2021 | 10:09 AM
travlee's Avatar
travlee
Master
you have a buddy that has a z? if so snag his switch to test
Old Apr 28, 2021 | 12:22 PM
Nickreich's Avatar
Nickreich
Made an account to post this.
There is this woman that frequents the bar I work at work at. She is like 70 and drives a 2004 6-speed. Window was stuck down. Held the switch up and banged the **** out the door panel and sure enough it inched backed up.
Old Jun 27, 2021 | 12:20 PM
Larry Wightman's Avatar
Larry Wightman
Default Crazy
I came here hoping to find an answer to my sudden passenger window not rolling up. decided 🤷‍♂️Got nothing to lose an it worked! You guys rock thanks.
Old Jul 31, 2021 | 04:35 PM
Larry Wightman
Default So which is it
So is it the Window motor or the regulator?
