How do i remove the headlight assembly???
Old Mar 25, 2006 | 03:40 PM
350ZTrackspec's Avatar
350ZTrackspec
Default How do i remove the headlight assembly???
One of my globes a busted and i need to remove the assemble! How?
Old Mar 25, 2006 | 03:45 PM
rythex's Avatar
rythex
There are about 4 bolts to remove off the headlight.. you will need to take the bumper off... So that involves taking all of the bolts off the bottom splash plate, inner well liners... then after you pull the bumper off it will be easy to unbolt the headlight and unhook the harness.
oh wait, what do you mean by globe? bulb?
Old Mar 25, 2006 | 03:53 PM
350ZTrackspec
All i know is one of my headlights aren't working. Not familiar with the lingo.
So your telling me i need to remove the whole front bumper to get to the headlight? Or do i just take apart the inner wheel liner and access it from there?
Old Mar 25, 2006 | 04:43 PM
drifter23's Avatar
drifter23
Here is a pdf file that might help you in removing your headlights.
http://www.ricks2k.com/info/instructions/350Z.pdf
Old Mar 26, 2006 | 06:37 AM
Netko350Z's Avatar
Netko350Z
If you are just going to replace the bulb all you have to do is remove the inner fender cover.
Old Mar 26, 2006 | 07:39 AM
XtaZee's Avatar
XtaZee
To replace the lower high beam bulb, you need to remove the fender protector.-
In order to replace the upper low beam, the front bumper must be removed in order to remove the headlamp assembly.-
Afterwards, perform an aiming adjustment.-
Old Mar 26, 2006 | 07:40 AM
rythex's Avatar
rythex
k, for some reason i thought you meant your light was actually broken... hehe
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
JGee450
Sep 30, 2015 04:32 AM
