My fix for seat moving/clicking
Old Jan 13, 2005 | 03:41 AM
  #81
jeffa55's Avatar
jeffa55
No problem... if you have any problems let me know and maybe I can take some pics of what I did and email them to you
Old Mar 23, 2005 | 12:03 PM
  #82
G I Love My Car's Avatar
G I Love My Car
Just to let everyone know, this does fix the movement problem BUT I had a serious popping noise coming from where I drilled the hole and put the pin in, once I took the pin out the noise went away but the movement came back. What I have found is when you drill the hole DO NOT put it as close to the frame as possiable, give yourself a little room and put a rubber or plastic washer between the frame and cotter pin to stop any noise from the pin against the seat frame. I was the only one that I have heard that had the popping noise but I would hate for anyone else to have to deal with what I did for several weeks. It almost made the car not fun to drive anymore.
Old Mar 24, 2005 | 09:30 PM
  #83
BROKE's Avatar
BROKE
Exclamation
I am sick of dealing with the drivers seat moving, clicking and squeaking i could puke. Everytime i ask them fix it they make it worse. I have had the car in for drivers seat noise/shifting problems at least 6 times (I am 6' 1" and 200 lbs). One time they didn't even bolt the seat belt latch to the seat frame. The POS seat now squeaks with every bump in the road, every turn of the steering wheel and every breath i take. This alone is enough to make me wish i never bought this car. Not to mention my 6 window lift replacements...3 drivers side & 3 passenger side lifts in 18 months... The passenger window is now covered with grease and sounds like someone is hitting the door with a baseball bat everytime i move the window up or down. Have had oil leaking out of the drivers side valve cover for 2 years...to date, Nissan has been unwilling to fix it, car smells like an oily 25 year old pickup truck (you know the smell i'm talking about) -> drivers side of engine block is coated with oil...NISSAN service sucks.....NEVER WILL I BUY ANOTHER NISSAN!
Old Mar 26, 2005 | 02:16 PM
  #84
DAYTONA-ZED's Avatar
DAYTONA-ZED
Originally Posted by BROKE
I am sick of dealing with the drivers seat moving, clicking and squeaking i could puke. Everytime i ask them fix it they make it worse. Nissan has been unwilling to fix it, car smells like an oily 25 year old pickup truck (you know the smell i'm talking about) -> drivers side of engine block is coated with oil...NISSAN service sucks.....NEVER WILL I BUY ANOTHER NISSAN!
My seat clicks as well. Yeah , sucks to have a warranty thats basically worthless. My dealership service dept has been zero help as well. My next project will be adjusting the headlights up. I dont even consider wasting my time with the service dept as the standard answer will be after the car sits there for a day " they are adjusted as designed" . Whats ironic is that the same guy owns both the chevy and the nissan dealerships and the chevy service dept was outstanding.
Old Mar 26, 2005 | 08:07 PM
  #85
BROKE's Avatar
BROKE
My passenger side headlight lense has a cloudy buildup inside; the drivers side is clear and still looks new. Any suggestions as to what is causing this cloudy buildup? I keep the Z garaged or car covered when not on the road.
Old Mar 28, 2005 | 06:42 PM
  #86
Jung918's Avatar
Jung918
does anyone have a picture of the completed project?
Old Mar 29, 2005 | 09:27 PM
  #87
DAYTONA-ZED
click here
http://www.infinitihelp.com/Ownershi.../ITB03-051.htm
Old Mar 31, 2005 | 06:05 PM
  #88
BROKE's Avatar
BROKE
Thanks for the link DAYTONA-ZED. I have had water condensation in both headlight lenses from time to time but as the TSB explains, the moisture always disappears. My problem is that the inside of the passenger side lense always has a mottled cloudy appearance while the drivers side is always clear. And the cloud is growing with time. I thought it might be waterspotted from evaporated condensation but then I would expect both sides to look the same. It looks like a cyclops! Maybe the lense is cracked where I can't see it and gunk is entering on the one side and mixing with condensation, when it is active, then being left as a cloudy haze when the water evaporates.
Old Apr 12, 2005 | 11:42 AM
  #89
specialp's Avatar
specialp
This fix really works and it only takes 15 minutes if you have everything together. I could actually see some wear on the end of the bar. If you have side airbags, it will not be a problem if you do not turn on the car while your seat is out, and do not short the pins in the plug (hard to do unless you stick a paperclip in there or something!)
Yes there is a TSB out and the dealer will fix it, but bringing your car down there is a PITA and having them give you some crap while they keep your car for days is not worth it either.
Old Apr 12, 2005 | 12:00 PM
  #90
pulpz2's Avatar
pulpz2
Couldn't resist!
Attached Thumbnails My fix for seat moving/clicking-5350z_gal_med12.jpg
Old Apr 28, 2005 | 04:41 AM
  #91
tacomaboy's Avatar
tacomaboy
Wow... TWICE I had taken mine into Nissan and TWICE they made it worse if anything!
Why couldnt they just do this simple fix. Took me 30 minutes last night! It worked like a charm! THANK YOU! (I should have done this months ago).
Old Apr 28, 2005 | 11:33 PM
  #92
DAYTONA-ZED
Did you have to remove the seat to do the fix?
Old Apr 30, 2005 | 06:09 AM
  #93
tacomaboy's Avatar
tacomaboy
Yes, but if you have a long enough drill bit you dont.
I dont have side air bags, so it was easy enough to remove and made the work quick. Still.. no shifting!
Old Apr 30, 2005 | 08:18 AM
  #94
zPilott's Avatar
zPilott
and it is only 4 bolts and a couple of plugs
Uriyo_
Sep 8, 2021 08:46 AM
3vilbunny
Jul 18, 2017 05:10 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
