Need help on the Error Codes... Cam sensor problems?
Old May 25, 2006 | 09:52 PM
mistaboosta's Avatar
mistaboosta
i'm keeping an eye on the timing when the problem happens. I'll let you know if i get some results mate.
Old Jun 6, 2006 | 06:57 AM
lowlife350Z's Avatar
lowlife350Z
i got the same problem but its at 4500+ RPM's and I got the code and it was a crank sensor problem. My tuner said it could be 2 things ither the crank sensor wire need to be more insulated due to too much heat, ither coming from a turbo, supercharger and even a header set up. Or a tooth next the the flywheel could be chiped and its reading a bad signal. "I hope its not that" also some else in this thread said it could be due the alot of oil changes which I do every 3000km and it could just be cloged.
Old Jun 19, 2006 | 12:30 PM
Dirty Dave's Avatar
Dirty Dave
Ive been following this thread for a while, im having the same problem with the p0011 code constantly popping up, have any of you guys found a solution yet ?
Old Jun 20, 2006 | 05:32 AM
EM-EFER's Avatar
EM-EFER
I am going to change out the cam sensors/crank sensor this weekend to diagnose further.
Old Jun 21, 2006 | 06:54 AM
EM-EFER's Avatar
EM-EFER
bumpity mchumpity
Old Feb 5, 2007 | 09:34 PM
gcoupeturbo's Avatar
gcoupeturbo
i have the same problem, but i narrowed it down to installing my flywheel at the wrong position.. i don't remember installing it to line up with the dowel on the crankshaft bolts.. i think it may have come off, and i didn't line it up right upon installation... i am reinstalling the flywheel again in about 2 weeks.. I will let you know and keep everyone informed if my engine codes go away (P0011 and P0021)
edit:/ yup the engine codes went away.. the flywheel was at the wrong position, it wasn't lined up with the dowel on the crankshaft
Old Oct 20, 2007 | 08:33 PM
track1z's Avatar
track1z
WHAT the GOdamn F*CK S^IT is this? SON of a god da*n bi&ch mother f%cker.MANNNNnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn I guess I'm pulling the transmission out tomarrow SHIUT SHUIT SHIUT!
Old Oct 20, 2007 | 08:40 PM
track1z's Avatar
track1z
Sorry for all who I offended.I checked the cam sensors 2 dozen times. The wiring dozen times Pulled the intake off along with the valve covers NO debris found. I have both cam sensors popping aswell. I'll get back with ya'll soon
Old Jan 16, 2008 | 06:43 PM
ryan350z's Avatar
ryan350z
Ever figure this out???
Old Jan 25, 2008 | 05:33 AM
Havok_RLS2's Avatar
Havok_RLS2
I just had both of mine replaced under warranty for the same issue. Everything back to 100% now. Easy fix.
Old Jan 31, 2008 | 04:14 PM
350zPinoy's Avatar
350zPinoy
God.... im having the same problems... took my car to the shop and got p0011 and p0021 . The shop replace the sensors, and my SES light is still on, replace it again SES light can off...but now every time i rev the car to 2500 rpms it starts to jerk took it back to the shop and i havent gotten it ever sinces. This totally sucks.
Old Feb 1, 2008 | 06:14 AM
ryan350z's Avatar
ryan350z
well I replaced the bank 2 sensor and all has been good for 200 miles. It would toss the code after 15 miles.
Old Feb 1, 2008 | 06:15 AM
ryan350z's Avatar
ryan350z
Let me take a look at the service manual and see if i can help you....
Old Sep 15, 2008 | 10:08 AM
ADMAN's Avatar
ADMAN
Any more info or updates on this???
Old Mar 14, 2012 | 07:10 PM
rparrish22's Avatar
rparrish22
Flywheel seemed to solve the problem. It was installed one notch to the left. Lined up correctly and it does. Not throw a code parked. Driving tomorrow to see if it pops up again. Thanks Gcoupe.
Uriyo_
Sep 8, 2021 08:46 AM
