Full turn on steering wheel squeaking from pulleys
Old May 10, 2006 | 02:13 PM
mikerz's Avatar
mikerz
Default Full turn on steering wheel squeaking from pulleys
Ok, so I finally got the chance to tighten my belts. I tried turning the steering wheel either all the way to the left or right with aircon on I hear a squeaking noise again.
But if ac is off no squeaks.
What needs to be done to fix this?
Old May 11, 2006 | 04:29 AM
mikerz's Avatar
mikerz
Bump
Old May 11, 2006 | 10:52 AM
Black_Sunshine's Avatar
Black_Sunshine
The belts may just be old and dry. A dab of toothpaste on the belt(s) may alleviate the problem, albeit temporarily.
Old May 11, 2006 | 09:19 PM
mikerz's Avatar
mikerz
Just drove my car for less than 50 miles on the belts.
Old Feb 19, 2010 | 08:10 AM
shemansky's Avatar
shemansky
I have the same problem and my belts are new
Old Feb 19, 2010 | 08:26 AM
Motormouth's Avatar
Motormouth
dear internets,
tighten my belts for me.
kthnkxsbai
Old Feb 19, 2010 | 04:35 PM
gregom's Avatar
gregom
Do you mean squealing from belt, or squeaking the actual rotation of one of the pulley's?
Do you have a copy of the Field Service Manual for your year and trim of car? In it there is a section on replacing drive belts, and it specifies the amount of tension you should have, which you can measure by applying a specific amount of weight to the belt between pulley's and and it should deflect downward a specific length. They specify how to get the tension set just right.
If the tension is correct, it may be a bad belt... take it back to where you bought it from and say it is squealing and request a replacement.
BTW even with the aircon off, the belt is still being driven by the engine, just the compressor disconnects its drive motor so there is no resistance being applied to the belt. So the belt is always going even if the aircon is off.
Obadabot
Jun 18, 2023 11:31 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Depravity
Oct 1, 2015 04:49 PM
