Current Alignment Specs????
Old May 11, 2006 | 10:55 AM
jeffw's Avatar
jeffw
Default Current Alignment Specs????
Anyone have the complete and current alignment specs that Nissan is recommending? I'm having trouble searching the site or the web to find the specs. Does someone know? I need them so I can take the specs to the auto shop when I get new tires and I'm afraid they'll have old specs in their computer (and result in feathering again).
I am interested in the specs for an '03 Track model (if it varies with model).
Thanks!
Jeff
Old May 11, 2006 | 11:57 AM
Z4ToddB's Avatar
Z4ToddB
JeffW-
Not sure if this is exactly what you're looking for, but there are some specs in here around page 16 or so. Hope it helps-
Regards
Todd
http://www.nissanhelp.com/Ownership/.../NTB04-043.htm
Old May 11, 2006 | 03:53 PM
jeffw's Avatar
jeffw
Originally Posted by Z4ToddB
JeffW-
Regards
Todd
Thank you for your reply. It sounds like the only change is that Nissan now recommends that front toe-in be set to the maximum of 2mm.
My guess is that the alignment specs otherwise remain the same as they appear in the service manual. I have the 2003 manual and have attached a screenshot of the alignment specs. I've also attached a pic of the alignment info from the service bulletin link that you provided.
Can anyone confirm that the alignment specs I've provided are considered the most up-to-date?
Thanks,
Jeff
Attached Thumbnails Current Alignment Specs????-350z_alignment.jpg   Current Alignment Specs????-350z_alignment_update.jpg
Old May 15, 2006 | 06:25 AM
Z4ToddB's Avatar
Z4ToddB
I wish there would just be a "no kidding" fix. I had my car "supposedly" fixed late in 04 at Performance in Duarte, Ca. (car went in storage from 1/05 to 11/05 and wasn't even driven) Car was supposed to be re-aligned to the new specs to prevent the feathering, also got new front tires via the TSB. Guess what? Less than 5,000 miles later, here I am with the feathering and the loud growl on my fronts again! This really pisses me off, and I don't feel I should have to spend my own $$ to buy coilovers, new springs, etc to fix Nissan's problem. I too would like to find the exact specs so maybe I could get it re-aligned somewhere else. Anyway, I'm going to be paying closer attention to this thread and to the stickied thread at the top-
Later
Todd
Old May 17, 2006 | 06:43 AM
Z4ToddB's Avatar
Z4ToddB
JeffW-
I was looking through some of the pages on the "tire feathering" sticky and ran across these specs from one of the members...found it kinda interesting and thought I'd pass along...at this point, I'm willing to try about anything!
Best of luck-
Regards
Todd
"quote"
At over 21,000 miles, the feathering has not returned.
The last alignment specs performed on my car by the independent tire/brake shop were the following:
Front Caster
Left was 9.22 degrees by Nissan after 9.21 degrees by American Tire & Brake.
Right was 8.80 degrees by Nissan after 8.79 degrees by American Tire & Brake.
Front Camber
Left was -0.87 degrees by Nissan after -0.92 degrees by American Tire & Brake.
Right was -1.04 degrees by Nissan after -1.01 degrees by American Tire & Brake.
Front Toe
Left was -3/32 inches by Nissan after 1/32 inches by American Tire & Brake.
Right was 1/16 inches by Nssan after 1/32 inches by American Tire & Brake.
Total was -1/32 inches by Nissan after 1/16 inches by American Tire & Brake
"end quote"
Mattg350z
Oct 2, 2015 06:51 AM
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
