Car pulling to the right fix?
Old Jun 22, 2006 | 09:12 AM
cruddydude's Avatar
cruddydude
Originally Posted by sluggoZ
Take into the dealer.TSB# 03046 This bulletin came out on 9-16-04...so it could involve some '05 models. lol
Hmmm... I'm looking at NTB03-046, and it seems to be dated 4-25-03. I would have thought that Nissan would have fixed the issue by the '05 model year, but, I guess not.
Old Jun 22, 2006 | 09:46 AM
cruddydude's Avatar
cruddydude
Originally Posted by GaryM05
The modified compression arm changes the caster on the right front wheel. This makes the car track straighter, but you MAY find after the fix that the car doesn't seem to take right-hand corners quite as easily as it does left-hand ones.
Did you experience this on your Z?
Old Jun 22, 2006 | 09:47 AM
sluggoZ's Avatar
sluggoZ
Mine is dated SEP 16 2004.....Applied Vehicles 2003-2004
The '04 models were not out yet as of your 4-25-03 date!
Old Jun 22, 2006 | 04:11 PM
GaryM05's Avatar
GaryM05
Yes, and I had the TSB done, which mostly fixed the problem (although on some roads that appear to not have much of a crown, the car still sometimes drifts just a little to the right).
To be honest, though, the perceived worse turning response to right-hand corners makes this fix a double-edged sword.
Old Jun 23, 2006 | 05:44 PM
arejohn's Avatar
arejohn
Do you have the befor and after alignment numbers for the rod change.
I would suspect drift to the right could be reduced by increasing caster on the left side or reducing caster on the right side and that this would affect toe but there is no mention of checking alignment in the TSB before taking corrective action or after.
Camber and caster adjustments were made obsolete by using manufacturing processes that were tight enough that resulted in alignment being in spec at completion. It saves time and money.
etkms
Jun 19, 2022 06:30 PM
SonnyWu
Nov 24, 2015 08:19 PM
350Z Project X
Oct 17, 2015 05:16 PM
RyansZ33
Sep 15, 2015 05:54 AM
