Quick Fix: Foot Rest Problem
Old Jun 26, 2006 | 06:38 AM
Kabs's Avatar
Kabs
Default Quick Fix: Foot Rest Problem
I have read a few posts of people having the same problem. Their footrest is loose and moving around. This occured after they removed it to clean it. (Thats what happened to me). I figured out a way to fix this problem without having to buy a new footrest.
Step 1: Remove all the pieces of the footrest. Here is a pic of what they look like.
(dont mind the wet spots I just cleaned it)
The place where I am pointing 2 in this and the following pictures are the cause to the problem (atleast it was for me) The plastic "screw" thing that fits into this big hole is suppose to stop in this wedge. However this plastic is very flexible and after you removed it from the car it probably got stretched out.
Another problem I could think of was the actual metal screw attached to the body of the car which holds the plastic. I noticed that the plastic part will never truely "fit snug" onto this screw. My solution was this plumber tape or however it is. I just wrapped it around the screws a few times to increase its diameter and grip.
Now to fix the original plastic from stretching I simply used 2 rubber bands on each hole. I made it tight enough so that the head of the plastic screw did not fit. I did this becuase the rest of the "shaft" (go giggle ) has a smaller diameter.
The final step is to reattach everything the way it was. Remember when screwing those plastic screw things to the car to make sure they are holding tight and are not moving from side to side. If they do more add more of that tape (or any substitute you found)
And finally I appologize for the quality of the pictures...my camera sucks and so do my picture taking skills.
Old Jun 26, 2006 | 07:30 AM
Cool. Thanks for taking the time to post instructions and photos. You are the footrest guru.
Old Jun 26, 2006 | 07:31 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
Good job fixing that POS. Nissan broke two of them on me already - and replaced them free of charge. But it seems that everytime I bring it to any shop they rip that thing off and it gets messed up everytime! I was going to buy one that screws in but I will try the plumbing tape first.
Old Jun 26, 2006 | 09:15 AM
Kabs's Avatar
Kabs
rubber bands.... i swear they make the biggest difference.... try it out
I am so happy i fixed it myself... gives you a big satisfaction you know
Old Oct 4, 2007 | 10:53 AM
tgscordv6's Avatar
tgscordv6
great fix!
Old Oct 10, 2007 | 12:59 PM
VO...'s Avatar
VO...
Administrator
Originally Posted by ranton73
if you take them off properly you wont have that problem. they shouldnt be ripped off, take your time and dismantle it.
Thanks for the insight...
Old Oct 10, 2007 | 01:00 PM
VO...'s Avatar
VO...
Administrator
OP, great write-up and nice pics.
Old Oct 14, 2007 | 02:06 PM
DavesZ#3's Avatar
DavesZ#3
I have a slight modification to this fix. The teflon plumbers tape around the post really didn't do much to make the thing fit tighter. It's very thin, hard to wrap and slippery. I took some heat shrink tubing and shrank two layers of it to the posts. I found one that barely fit over the post and shrank it on first then the next size up that barely fit over it. I had to pound on the foot rest to get it back on the screw posts but it fits very tight now, almost no movment at all.
Old Oct 14, 2007 | 02:45 PM
Abishop's Avatar
Abishop
i need to try this!
Old Oct 14, 2007 | 02:54 PM
Jay'Z's Avatar
Jay'Z
I have this problem too.. Not sure if its worth fixing.. lol
Old Oct 14, 2007 | 03:12 PM
DavesZ#3's Avatar
DavesZ#3
My only concern with it being loose is when attending an autoX or HPDE, having the inspectors fail the car for it being loose. I've drive without it and it feels weird and would prefer to have it in the car.
Old Feb 2, 2009 | 07:39 AM
IB Systems's Avatar
IB Systems
Just fixed mine, I used electrical tape. Thanks for the great write up!
Old Feb 2, 2009 | 12:13 PM
VO...'s Avatar
VO...
Administrator
I can't remember how I ended up fixing mine. I think I just squirted some clear silicone in there...
Old Feb 2, 2009 | 01:47 PM
quakerroatmeal's Avatar
quakerroatmeal
Clear silicone? Sounds messy. I've noticed mines probably a tad bit loose but not a concern enough for me to actually take it off to fix it. Dang I thought I was nuts.
Uriyo_
Sep 8, 2021 08:46 AM
