Tech Help!!!!!
ok so I have an update, I built my motor and dropped it in but I couldn't get it to start so after troubleshooting I found I didnd't have spark.
After taking it to a shop, we found that I have power going to the coils but no ground!? What could be causing this????
Is is unsafe for me to ground them myself if I can't figure out how to fix the problem??? After all, its just 6 grounds that need to be run...
its a G35 coupe harness.
FYI: I have the tiny ground that bolts to the front timing cover hooked up, the ground on the driver side of the engine bay (the one right above the driver side exhaust manifold)., and I added a ground made with thick monster cable that runs from the front timing cover to where the driver side shock nuts are located.
Workshop12
Mar 23, 2020 01:45 PM
ILoveDrifting
Sep 7, 2015 03:15 PM
