2nd oil change... Needed less oil?
I've had 2 oil changes done by my dealer w/ Castrol Syntec... The 1st time my Z took 5 qts. The 2nd time they only used 4. The owner's manual lists the engine capacity as 5 qts... Is there any reason why it might take less, or did the service guy do it wrong? I can always add the 5th qt myself.
I talked to the tech... He said the oil level was OK on the dipstick. I'm going to check it myself, but assuming he's right, should I even bother adding a 5th qt?
It took my engine a long time to drain (over 10 minutes) and it only took 4.5 quarts to get to the middle of the zone on the dipstick. It was hot and I did change the filter. If you don't wait for it to drain fully or don't change the filter it will take less to fill it up.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
