Dipping Idle after revving engine??
Old Aug 8, 2006 | 06:16 AM
PGT313's Avatar
PGT313
Default Dipping Idle after revving engine??
A couple of weeks ago my MAF sensor went weird on me and the car wouldn't idle for long before stalling. I took off my CAI and used MAF cleaner on it. Once i was done with the MAF cleaner and put everything back on it ran like brand new again. Now 2 weeks later the idle will dip after coming off of a higher RPM.
Example. Coming to a normal stop from about 20mph, when i put my foot on the clutch to coast, the idle dips below and then jumps back before it becomes normal? It never actually stalls though. It will even dip with the A/C on.
Any ideas?
Thanks!!
-Peter
www.izzaro.com/z
Old Aug 8, 2006 | 02:04 PM
Gryphin's Avatar
Gryphin
is your filter on your CAI really oily? if so let it sit outside in the sun for a couple hours...
Old Aug 8, 2006 | 02:49 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Possibly reset your ECU, remove negative battery terminal and pump brakes a few times. If that doesn't work, remove negative battery terminal overnight (12+ hours)
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
