rough idle
Old Mar 1, 2003 | 12:58 AM
volk z's Avatar
volk z
Unhappy rough idle
have a le mans sunset 2003 track with 425 miles has a rough idle was wondering if others are experiencing same problem warm or cold just rough idle
Old Mar 1, 2003 | 01:34 AM
s9am_me's Avatar
s9am_me
can you explain by what you mean by rough idle?? like the needle jumping around during idle??
Old Mar 1, 2003 | 03:31 AM
westpak's Avatar
westpak
SFZCC
Install a grounding kit it helps.
Old Mar 1, 2003 | 06:17 AM
Enforcer's Avatar
Enforcer
Default Re: rough idle
Never had idle problem (6000+ miles). Recommend you take to your dealer and have it checked soon.
Enforcer
Old Mar 1, 2003 | 06:34 AM
ares's Avatar
ares
Veteran
it does help, or maybe Im crazy . but even so, before installing it, Im not sure Id describe it as "rough". just not as smooth as it is now(in my head right?)
Id agree, bring it in, make sure it all checks out.
Old Mar 1, 2003 | 12:52 PM
volk z's Avatar
volk z
Smile
you feel the roughness in the stick and yeah some needle fluctuation ill try the ground ing kit first what brand do you guys recomend
Old Mar 1, 2003 | 04:17 PM
Intrepid's Avatar
Intrepid
The Insaneamine Grounding Kit for the 350Z is THE BEST kit you can buy. It's $75 plus shipping. It comes in many colors and he ships fast.
See Here for Details:
https://my350z.com/forum/showthread....ight=grounding
To Order, Send a private message to insaneamine or email him at: insaneamine@***.net
Old Mar 1, 2003 | 05:36 PM
ares's Avatar
ares
Veteran
the car is rwd, and nissan weighed their options, either offer bushings to reduce vibration in the stick, or not and get a tighter feel. they chose the latter, and Im glad. however just be aware that the grounding kit wont fix this, the stick will always vibrate a little bit, its directly bolted to your transmission, no rubber to absorb the vibrations.
Old Mar 2, 2003 | 03:12 AM
s9am_me's Avatar
s9am_me
yeah i just got the kit from insaneamine... very nice workmanship. Its all pre-cut, crimmped, heat-shrunk for you. Just gotta bolt it on and thats it. Haven't really noticed much difference. this might be off the wall but does the ECU need to get used to it???? Haven't taken it past 4K yet though
Old Mar 2, 2003 | 08:25 PM
A17Z's Avatar
A17Z
i noticed my car would misfire during idle. the dealer hooked up consult and found out that my 2nd cylinder injector was bad. i'm waiting for all the parts to come in for them to replace it. you may want to have them check it out.
Old Mar 2, 2003 | 10:10 PM
volk z's Avatar
volk z
Unhappy
2nd cylinder injector humm seems like everybody finds a new problem everyday oh well still love my Z =)
liqalu04
Jan 2, 2022 12:58 PM
hulkout
Apr 28, 2017 09:00 PM
ablaine
Nov 29, 2016 10:13 AM
Darkspy
Sep 7, 2015 09:09 PM
