E-Brake light question
Old Nov 12, 2006 | 08:13 AM
michaeljr6's Avatar
michaeljr6
wow this thread SOLVED my problem!!!!! thanks guys!!!!!!
Old Nov 13, 2006 | 02:06 PM
VO...'s Avatar
VO...
Administrator
+1 on low level fluid. check pads 1st. If they still have some bite left in them, add fluid. As your pads wear down the fluid level will get lower. If you install new pads, the level will raise. They relate directly to one another......
On the other hand, if your keep having to add fluid, quite often, you most likely have a leak.
issyz
Jul 2, 2017 03:04 PM
Vigman
Nov 17, 2015 04:34 AM
nanotech
Oct 2, 2015 05:02 AM
