need help asap im about to cry..
Old Oct 15, 2006 | 12:07 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
Default need help asap im about to cry..
i was installing my mrev2 and i thightened it too hard and broke off. need help i have school tomorrow too with test. how do i take out the broken peice
Attached Thumbnails need help asap im about to cry..-pic1.jpg   need help asap im about to cry..-pic2.jpg
Old Oct 15, 2006 | 12:10 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
need help
Old Oct 15, 2006 | 12:13 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
bump
Old Oct 15, 2006 | 01:00 PM
Ichigo's Avatar
Ichigo
Get another ride to school and have it taken to a shop.
You will need special tools to remove that, if you dont have the right tools, throw up the white flag of surrender. I believe Sears/craftsman sells a screw extractor, called an EZ Out:
http://froogle.google.com/froogle?q=...oogle&ct=title
http://www.sears.com/sr/javasr/searc...&gobutton=find
I'm not trying to be mean or a smart a$$ but sometimes your better off letting someone with the right tools and more experience finish the job. but this looks like an easy fix as long as the threads arent damaged.
Old Oct 15, 2006 | 01:10 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Take the lower plenum off. I bet the rest of the stud is still sticking up out of the lower collector. Put some vice grips on it and twist it out. You can use a bolt when you put it back together, just make sure you get the right size/thread.
Old Oct 15, 2006 | 01:14 PM
Ichigo's Avatar
Ichigo
Originally Posted by ZU L8R
Is it sticking out the back? If it is remove the lower plenum and put some vice grips on it and twist it the rest of the way through the bottom
+1
I didnt even think of that... I looked at my engine bay but could'nt see the referenced spot because of the cover.
Old Oct 15, 2006 | 01:18 PM
KwanZito's Avatar
KwanZito
yeah you can get the extractor set at Sears (i have one it's a great thing to have in your tool box). You could drill it out and re-tap it. But either way I'd say if you've never tried either of these manouvers before, your best bet is to get it to a shop and have them to it.
Or maybe you get lucky and you can get a grip on it from the bottom, then get a new screw. Either way I'd invest in a torque wrench asap. People laughed at me when I spent $80 on a torque wrench for this exact install, now I'm glad I did.
ZU L8R's Avatar
ZU L8R
Viper Sellout
Originally Posted by Ichigo
+1
I was thinking this was one of the bolts that hold the 2 plenums together, it's the stud that comes outta the lower collector. Still fixable, I edited my previous post. BTW, both studs are gone and I have bolts.
etkms
Jun 19, 2022 06:30 PM
LunchBox20
Oct 20, 2015 10:22 PM
