a/c auto mode acting weird
Old Oct 23, 2006 | 07:24 PM
rsx350z's Avatar
rsx350z
Question a/c auto mode acting weird
Hey, guys I tried searching but couldn't find anything. My a/c auto function fan is shooting air to the windshield instead of foward like it used to be. This started happening after they installed an avic-d2. Does anybody knows why is this happening, before i take it back to the shop that installed the navi. I tried disconnecting the battery but it keeps doing the same thing, also a/c is only cold right at 60 anything over is hot air comming out.
please help.......anybody? thanks
Old Oct 24, 2006 | 07:46 AM
julian's Avatar
julian
can you change it to panel mode (forward) manually or is it always stuck on defrost mode? if it's always stuck on defrost mode i'm guessing either an electrical or vacuum line to the HVAC system is not connected. modern HVAC's default to defrost mode when it fails.
Old Oct 24, 2006 | 09:20 AM
rsx350z's Avatar
rsx350z
it can be manually adjusted to forward position, only on auto mode goes to defrost. Do the plug connectors fit only in one position?, or maybe they were reversed or connected on the wrong spot.
Old Oct 24, 2006 | 09:56 AM
jtabraham's Avatar
jtabraham
+1
Check all your vacuum line connections. Happened in my last car, and i realized I removed a vaccum line an never replaced it.
Uriyo_
Sep 8, 2021 08:46 AM
burglapfd
Dec 6, 2020 01:04 PM
Jambo016
Sep 16, 2016 01:08 PM
kyin
Oct 15, 2015 05:54 AM
_bit
Oct 2, 2015 07:49 AM
